grsthegreat
Super Star Member
I agree, dino now has long changes. Problem is pull a UOA and then run a synthetic. In my case, a world of diff. I know Ford on there Powerchoke had issues with foaming etc.
pull a uoa? whats that mean
Elvis,
I think they do (my local Napa does) , but make sure it specifically meets the spec. Tractor fluid and regular hydraulic fluid are very similar, but the difference is that the tractor fluid has extreme pressure additives for gear contact protect, where regular hydraulic oil does not.
As far as the 0w-20, so far its an elusive beastie. I can only find it in synthetic, and for that matter, only Mobil 1 or Honda branded. Gotta change the oil in our 2010 CRV this weekend, so I'll be on the hunt.
BTW- I dind't mean to be too harsh in my last post. Most of it was to prove a point that synthetics offer a real service to those who may want or require it, but also my info is a little dated. I realy haven't put much time into oil research for a while, as it was an interest of mine that has kinda wained in the last few years.
No, It does. Just about every form of non-logic logic is posted here.
A few examples:
2) A ran 15w-40 dino and switched to 5w-30 synth, and in the cold, it started faster- thus synthetic is better.
That's enough for now..tired..
i also switched to rotella t6 synthetic in one truck too. not because i was worried about less frequent oil changes, but because on cold days this winter the diesel would actually start, but it would not pump the 15-40 oil through it. the 5-40 synthetic is noticeably easier on the engine at startup.
I was just wondering what the consensus is. It would be worth it to me I could go 5k with synthetic oil between changes instead of the 3-3500 I have been doing with conventional oil.
Is that safe? I drive my truck. Off road miles, dust, heavy towing (for a gas pickup) for a few k a year, most of my trips are a couple miles.
Does it even matter?:confused2:
No...
Oil changing and "sooper dooper wonderfully enhanced" oils are SO oversold.
Engines really HAVE come a long way.
Machining tolerances are tighter, things don't slop around so much, piston ring gaps are smaller, there is less blow by, less contamination from by products of combustion,,, on and on and on.
Bearings are assembled by group match, or "binning" of tolerance range.
Yes, it doesn't matter.
If anything needs changing it is the "mileage" guideline for oil change intervals.
I think "fuel gallons" would be a better measure.
It is probably one of the few measures of total work done, or total stress experienced by an engine.
You drive with a light foot, you get good gas mileage, you can go longer between oil changes.
You drive with a lead foot, you get poor gas mileage, you need to change the oil more often.
What say oil changes every 500 gallons of gas burned ?
Maybe 300 for diesel engines ?
I used to burn 3 gallons per hour in a boat, the recommended oil changes were every 50 hours - that would have been about every 150 gallons of gas.
That seemed too short an oil change interval - to me, but boats CAN be run hard for hours on end, so maybe others burned 3 or 4 times as much.
I agree on the fuel burned being a much better barometer than mileage. Even better would be fuel burned/volume oil in crankcase. This would compensate for engine size.
GM went from 7500 miles between changes to a counter that does some complex algorithm - figures number of cold starts, number of times the engine doesn't get to full operating temp, etc.
It wasn't popular, too many people were getting 10,000 or so miles between suggested oil changes and they DID NOT like it.
Old habits, old superstitions, die hard (-:
Throw that in with the conspiricy theorists that think its GM wanting to sell them another truck when that one blows up early cause of "long oil change intervals".
