Rotary cutter size for 1070
/ Rotary cutter size for 1070 #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
I am looking to get either a medium duty or heavy duty cutter for my 1070. I am sure a 5' would be no problem, but what about a 6'? Do any of you guys have any advice? FYI, the 1070 is 39hp with 35 at the PTO.
thanks!
/ Rotary cutter size for 1070 #2
I use to run a JD MX-6 (6 ft rotary cutter - rated for minimum of 30 HP PTO) behind my JD 4320 (40 HP PTO) with no problem. Any bigger cutting width beyond 6 feet will likely be too much for your 35 HP PTO. When transporting my MX-6 behind the 4320 I found I needed to go slower because the heavy attachment weight was like "the tail wagging the dog."
/ Rotary cutter size for 1070 #3
You should be fine with the MX-6; unless you plan on tackling 4" willows along the river bottom... :eek:
The weight of the mower is significant given the distance it hangs off the back end of your tractor but it's not so bad if you've got a FEL mounted, too.
I was planning to buy a MX-6 for my JD 970 as most average mowing work would have been manageable with the 30hp @ pto. My purposes were to keep the horse pasture trimmed up where the horses were skipping the less palatable grasses and leaving tall spots and "pool table" areas in a patchwork fashion.
No major brush work or reclamation of overgrown areas.
AKfish
/ Rotary cutter size for 1070 #4
I have used my MX6 with all three of my tractors in my signature with no problems. Obviously the 4520 will walk through thick brush without bogging down at all.
/ Rotary cutter size for 1070 #8
And a turbo kit... like the thread on the 2320 or the 755! :D
AKfish
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
John Deere 4040 Tractor (A64047)
John Deere 4040...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
