Rotary cutter size for 1070
/ Rotary cutter size for 1070 #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
I am looking to get either a medium duty or heavy duty cutter for my 1070. I am sure a 5' would be no problem, but what about a 6'? Do any of you guys have any advice? FYI, the 1070 is 39hp with 35 at the PTO.
thanks!
/ Rotary cutter size for 1070 #2
I use to run a JD MX-6 (6 ft rotary cutter - rated for minimum of 30 HP PTO) behind my JD 4320 (40 HP PTO) with no problem. Any bigger cutting width beyond 6 feet will likely be too much for your 35 HP PTO. When transporting my MX-6 behind the 4320 I found I needed to go slower because the heavy attachment weight was like "the tail wagging the dog."
/ Rotary cutter size for 1070 #3
You should be fine with the MX-6; unless you plan on tackling 4" willows along the river bottom... :eek:
The weight of the mower is significant given the distance it hangs off the back end of your tractor but it's not so bad if you've got a FEL mounted, too.
I was planning to buy a MX-6 for my JD 970 as most average mowing work would have been manageable with the 30hp @ pto. My purposes were to keep the horse pasture trimmed up where the horses were skipping the less palatable grasses and leaving tall spots and "pool table" areas in a patchwork fashion.
No major brush work or reclamation of overgrown areas.
AKfish
/ Rotary cutter size for 1070 #4
I have used my MX6 with all three of my tractors in my signature with no problems. Obviously the 4520 will walk through thick brush without bogging down at all.
/ Rotary cutter size for 1070 #8
And a turbo kit... like the thread on the 2320 or the 755! :D
AKfish
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
