Yanmar YB201
/ Yanmar YB201 #1
uncleseb
Yanmar 201 YB
hi , i have a yanmar YB201 . it has a startup problem. the engine starts very badly I am obliged to use the start pilot . hot engine if I let it stand for 10 minutes will not boot I have to use start pilot.
I don t have the manual for this engine (3T84) somebody could provide it?
I would check the pump timing.
Thank you for your help
Sorry for my little english
/ Yanmar YB201 #2
Have you performed routine operator maintenance, fuel, air filters? Fuel pumps don't get out of time unless they have been removed and shims removed or added. Is battery fully charged?
/ Yanmar YB201 #3
Does the engine have much blowby? Is it strong running when cranked? Any smoke of what color? Does it have a compression release?
/ Yanmar YB201
hi,
yes i have performed routine operator maintenance , the battery is ok.
When the motor starts with start pilote ,after it runs well.
When it doesn't wan't to start he have white smoke .
I don't know for the compression
/ Yanmar YB201 #5
All a diesel has is fuel, air, (intake and exhaust), and compression, assuming proper cranking speed. Only on-site troubleshooting can determine which is causing the problem. Valve adj. ok? Exhaust not plugged? water/air in fuel, good compression, about 500psi, (or eq. for your country)?
/ Yanmar YB201
hi , i wan't to vérify the valve clearance i don't have values ​​and the method, and i don't find manual for motor 3T84HLE
Anybody have it ?
/ Yanmar YB201 #7
hi , i wan't to v駻ify the valve clearance i don't have values ​​and the method, and i don't find manual for motor 3T84HLE
Anybody have it ?
Probably about .008" but that is only a guess. Pretty sure Danny Parker with Parker Equipment (Untitled) has that information. Here is a guide on setting valves. Yanmar Tractor Valve Setting
/ Yanmar YB201
many thanks .
Do you have information about timing pump ?
/ Yanmar YB201 #10
Have you had the pump off? If not, your timing should not be off. If so, put it back with the same shims.
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
Wooden Glider Chair (A64557)
Wooden Glider...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
