John Deere Power beyond
/ John Deere Power beyond #1
rjslota
Ocean County, New Jersey
John Deere 4110
Hi, I installed a power beyond system on my John Deere 4110 to run a Tractor Supply log splitter and am having trouble getting it to work. I guess i'am not bleeding ot righe or does it take a lot of effort to charge the system. Thanks Ray
/ John Deere Power beyond #3
i have a JD870 with power beyond. My system came with a loop hose connected to both rear ports.
i simply disconnect the loop, and connect my splitter to the rear ports. My splitter has an OPEN CENTER valve attached, and it only took about 10 seconds to charge up prior to 1st use.
make sure your splitter has the open center valve.
i went to tractor supply site, and i see a 3 point splitter there, it says it comes with a diverter valve to set up as a closed system. dont use that. Also, did you pipe directly to the power beyond ports? or thru a valve on the tractor?
Thanks but I addressed those points already, as soon as it warms up I'll start over. Once again thanks
/ John Deere Power beyond #6
You did install the little set screw looking thing inside the valve block didn't you?
There is no need to bleed anything, the system will purge the air just by cycling the controls.
There was nothing in the "$%#@" direstions about a set screw. I have to look back into that. It ram does move a bit but no real power. I need to have a nice day and mess with it. Thanks for the tip.
/ John Deere Power beyond #8
Look at the picture below, You have to install the screw (#17) in the block that's between the valve and the tranny. It blocks the flow of oil back to the tranny case and diverts it into the OUT port of your PB lines. When this is not in place, your two valves (on the splitter and FEL) are in parallel and neither will operate correctly.
Well acording to the JD directions you use the internal plug on units without SCV. What is the valve your kalking about you mentioned it with the splitter. I have 2 6ft hoses that have to be charged thats why I think it has to be bleed.and fluid added to the tractok. Thanks
/ John Deere Power beyond #10
my splitter has a 4 foot and a 3 foot hose. the tractors hydraulics are self purging, meaning just run it and they bleed themself. mine only needed a few seconds to operate. The valve on the splitter has to be set for open center operations.
/ John Deere Power beyond #11
Your splitter has a valve on it...that's what I was talking about.
Again, the system is self-bleeding so all you have to do is cycle the splitter cylinder to remove the air.
The plug ( "C") is NOT what I am referring to. The directions do not really address the one I am talking about. It is installed in the block that mounts between the SCV and the tranny.
Do you have the screw (plug) in your leftover parts?
Well your going to love thius. Today was nice so I decided to mess with the splitter. Everything checked out but no splitter. I disconnected the kuick connect and started the tractor then pressed the quick connector with a brass shaft and got all kinds of fluid out. Reconnected it and still no splitter. So I disconnected one of the lines to the cylinder and worked the valve, no fluid. Phone time. The teck couldn't figure it out but he said to check the check ball and spring under a nut near the valve lever. Well I would but there was no spring or ball, WOW how the H#$% is this thing going to work with out that stuff. Moral there sending me a new valve. I'am glad I didn't take the tractor apart. Thanks for your help and I'll post when I get the valve to let ya know it it works.
/ John Deere Power beyond #13
Don't you guys just love a happy ending?
Nce job, rjslota!
Ya can't make this stuff up. I made a mess but I think I found the problem. I'am just happy I didn't take the tractor apart first.
/ John Deere Power beyond #15
He never did say if he installed the PB screw, and where are the pictures of what was under the cap and nut on the log splitter valve. Just don't make sense. Was that a new log splitter?
If you did not install the screw in the PB port, it is not going to work right.
Goodmornin, I looked at the directions again for the 10 bizzilionth time. You mentioned a screw?? I see what you mean but the directions are split into 2 parts. #1 "Installing" Hydraulic Block, tractors without SCV. Like a front end loader which I have. In that section they want you to insert a new internal plug and replacing a cap with an O-ring in the replacement block. now in #2 "Replacing" Hydraulic Block, it dosn't want you to do that, ya just put the new block in as supplied. Trust me it's still driving me nuts but it seems clear as mud in the directions that it dosn't mention the screw, plug in the replacement block. I just wish I hade someother att for the power beyond system to hook up and test just to put to rest the screw job issue. Well thanks and I'am still messing with it waiting for the new valve from the splitter co.
I see what your talking about but the directions don't tell ya to put it in when you have a SCV. As I installed the block the tractor is working fine, loader and 3pt hitch. I'll try and put the 2 pages of the directions on for you to see. Thanks102_2241.JPG
/ John Deere Power beyond #19
RJ, I have the instructions...I know they don't tell you-I am trying to!. That is why I wrote this in my other reply:
The block they gave you in the kit is IDENTICAL to the one you removed and you MUST install the screw!
I went through the same thing with mine when I installed the PB kit and had to take it back apart to install it.
Once again I ask: Do you have the screw in with the leftover parts?
OK, I didn't check what I have left over, I always look at that as a job well done when you have stuff left over. So you had the same problem? I think tomorrow I'am going to disconnect the return quick connect and start the tractor and engage the splitter valve, QUICKLY. If it moves then that tells me the 2 lines were, are, charged and working against each other, thats why its not working. Sound logical??? I assumed everything was OK because everything on the machine was working normaly. I even pressed the quick connect while it was running to make sure It was pumping and it was, MESS. By the way THANKS for your input, I'll keep you informed. If you want my email rjslota@comcast.net it might be easier then this site I always have trouble retriving the old messages, am I doing it wrong or will I ever figure it out. Thanks Ray
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
Caterpillar 980B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980B...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
