Photos of Third Function Valve Project
/ Photos of Third Function Valve Project #21
Although the data page shows the relief set at 2000 psi, the Instructions say that the valve is factory set to 2500 psi. I would install a gage and set it equal to the PRV psi on the FEL.
Thanks j_ j I will make sure I do that. Not sure about these things.
Is this thinking right ? If I put a guage at the pump output or before the FEL valve and operate the loader to a stop I will see the FEL PRV setting. If I then operate the grapple to a stop I will see the grapple valve PRV setting.
Correct me if I am wrong. Appreciate your help.
After further reading I can see this is not quite right. In both cases the guage would show the same reading - which ever PRV is set Lowest.
Just talking to my self here - Do it all the time
/ Photos of Third Function Valve Project #24
The two PRV's should be set the same unless you want to protect the grapple with less pressure. Depends on how well the grapple is built.
/ Photos of Third Function Valve Project #25
Thank you for taking the time for the detailed write up. I've been chewing on ideas for ways to plumb a grapple and keep my remotes free for rear implements and the valve configuration you chose seems to be precisely what I'm looking for. My hyd is an open center setup, so I,ll have a couple less hoses to run, but I like your way better than the other ideas I was thinking of (elec/hyd switch valve wr long style or giving up a remote.) I only have to find a 11gpm 1 spool valve to match the flow of the walvoil valve on my BH 2426 loader since I'll be piggybacking it inline after the loader valve and don't want to choke the loader.
I think I'll go with this one.
Many thanks!
/ Photos of Third Function Valve Project #26
I am in the process of installing this set up on my L3200. Same valve... Question on the "internal H.P. carryover plug (1/4-18BSPT)", it seems odd but I just want to make sure this plug needs to be installed inside the PB port for this set up. You did install this plug correct?
/ Photos of Third Function Valve Project #27
If you are feeding the next valve, you need the PB adapter.
/ Photos of Third Function Valve Project #28
JJ, are you speaking about the little plug that goes into the power beyond on the new valve?
/ Photos of Third Function Valve Project #29
Yes, that plug is necessary to separate the main flow from the OUT flow.
Some valves use the hex screw, and other valves use a PB adapter sleeve.
If you are talking about the valve in post 25, it uses the PB sleeve.
If you look in the PB port, if it has a small 1/4 in threaded hole, then it takes the screw.
If the hole is larger and has a seat for an o-ring, then it takes s PB sleeve.
I posted both kinds.
You should use the part made for your valve.
/ Photos of Third Function Valve Project #30
Perfect! Thanks JJ.
/ Photos of Third Function Valve Project #31
Third Function Valve Project/ valve question for the hydraulic guys
I have been looking at adding a grapple & after looking at MANY thread I think I would prefer Gordon's set-up to an "electric over hydraulic" control.
I have access to an open center valve that is about the right GPM but doesn't have a power beyond port.
Going by Gordon's hydraulic diagram, could the PB line from the loader valve be "T'd" to feed both the 3PH & the new grapple control?
/ Photos of Third Function Valve Project #32
Re: Third Function Valve Project/ valve question for the hydraulic guys
No, tees are not allowed as the flow would travel to the path of least resistance.
All valves in an open center hyd system should be in series.
If you are talking about a solenoid valve, and DO3 subplate, most hyd blocks are high pressure, so just add the 3rd function valve in series with the FEL and the grapple.
You do know a solenoid valve will provide full flow to the grapple.
I assumed you were talking about a solenoid valve.
However, look at the lever valve specs and see what the tank ports rating is. What is the manufacturer and model number of the valve?
If it says the max tank port is about 500 psi, that is the highest pressure or back pressure that the valve should see.
If you choose to use it anyway, , you are at risk of damages.
Why not use a diverter valve to control a grapple?
http://www.surpluscenter.com/Hydrau...-VDC-13-2-GPM-SAE-8-DOUBLE-SELECTOR-VALVE.axd
http://www.surpluscenter.com/_MoreSpecs/i9-7852.pdf
/ Photos of Third Function Valve Project #33
Thanks for the reply JJ. Makes sense that it wouldn't see any flow. I'll just source out the right type.
/ Photos of Third Function Valve Project #34
The valve I was asking about is a regular lever type valve that I could get inexpensively from a friend, but no power beyond. Not sure of the make/model as I haven't seen it.
I do realize that the solenoid-type is full power on/off which is why I am interested in the all-hydraulic type in this thread.
/ Photos of Third Function Valve Project #35
This is just about typical of a valve description.
SPECIFICATIONS
Pressure Rating
Maximum Operating Pressure ........ 3000 psi
Maximum Tank Pressure................... 500 psi
Nominal Flow Rating ...........................30 G
This kind of valve could be used as the last valve in a hyd system, but when used on a tractor, the 3pt is the last valve in the system.
You might get away for a short time with luck and use that valve in a series system, or it may last a long time if you don't over pressurize the hyd upstream , which is typical when you are using the 3pt.
/ Photos of Third Function Valve Project #36
So I blindly ordered the fittings exactly off the parts list previously posted here. The hydraulic diagram calls for 90s (ORB to JIC) for every direct valve connection. The 90's on the Tank/PB and output ports cannot be installed at the same time due to their close proximity. In other words, they cannot be installed at the same time due to clearance issues. I am aware that I can buy more parts but I'm wondering how no one else has had this issue? Also, a recommendation on the cheapest way to correct this would be appreciated. "Long" fittings are not cheap compared to their short counterparts.
/ Photos of Third Function Valve Project #37
Straight ORB to JIC, then a standard 90 degree JIC swivel fitting.
/ Photos of Third Function Valve Project #38
I used ORB standoffs on my setup.
/ Photos of Third Function Valve Project #39
There is an alternative to JIC fittings and expensive angled hose end fittings...the alternative is NPSM swivel fittings...They are mechanical fittings that require NO sealant or tape etc...they are actually more robust than JIC flares...
Using NPSM adapters (can be had with most common port threads, SAE/ORB, NTP, etc., etc...) can make ordering hoses a breeze if you use NPSM adapters on the valves/cylinders etc... hoses can be ordered with nothing but straight NTP threads (very inexpensive) and there is no orientation to worry about when both ends of a hose require an angled fitting...
SAE Straight Thread (ORB) scroll to the bottom...
Female Pipe Swivels (NPSM)
/ Photos of Third Function Valve Project #40
I ended up ordering from discounthydraulichose this morning what I think will work. Male ORB to female JIC with swivel nut. That should allow me to screw the ORB Male into the valve, then tighten a male JIC 90 onto the new fitting. I ordered two JIC Male to JIC Male 90's as well. Assuming I am interpreting the definition of "Swivel" correctly I believe this will work?
6402-08-06 | #8 SAE/ORB Male x 3/8" JIC Female
[Edit] Insane.. I ordered hyd oil direct from Schaeffer Sunday evening. I just got my tracking number today, UPS has yet to receive the item. I ordered fittings from discounthydraulichose at 8:30am this morning and USPS has already received the package as of 5:30pm. I may not get to use my new grapple this weekend not because of the fittings I ordered today but the oil I ordered Sunday.. LOL
