Full Paint Job
/ Full Paint Job
/ Full Paint Job
I'm done. Here's the finished paint job.
There was some earlier discussion about 5 ft. & 10 ft. paint jobs. I used a brush & roller for all the painting - mostly touchups. I call it a 20 ft., candlelight, 20/100, paint job - best viewed from 20 ft in dim light without your glasses.
At least all the metal is protected.
/ Full Paint Job #45
What brand of paint did you use?
thanks,
reed
/ Full Paint Job #46
The pictures look good. I looks like a professional job. You are probably the only one who is really going to look at it up close, and as you said, at least the metal is protected.
/ Full Paint Job #47
Excellent results!
later
/ Full Paint Job
thanks,
reed
Kubota Orange from Carquest (their part no CFP 4707-GL). $45 / gallon. Good match. I started using rust oxide colour primer but found coverage was much better over grey primer.
/ Full Paint Job #51
It looks pretty darned good to me no matter how you did it.
/ Full Paint Job #53
Kubota uses a light tannish color primer. So you were wise to switch to a lighter color. Kubota doesn't use light primer to lighten their color, they do it for easier coverage with less paint.
Good job. I like how you detailed it including adding stickers. Very professional from my seat. And very time consuming!!! :thumbsup:
/ Full Paint Job
Not time consuming - all decals are original. I just painted around them.
/ Full Paint Job #56
Have you figured out where to put a tool box on this tractor yet? After many weeks of thinking about it, I have a plan but it won't work with a backhoe. Not a problem on mine.
/ Full Paint Job
I haven't really thought about a tool box but it sure would be useful. I expect the backhoe will be on most of the time. Anybody have a suggestion?
/ Full Paint Job
I thought I would give the machine a try at home before its one way trip to the cottage. I cut a cedar bush down last year leaving the roots. Last fall I bought a thumb & finger from Brotek. I haven't used the thumb yet but this gave me a chance to give that root the finger.
/ Full Paint Job
I'm finally putting this little beast to work. Lots of fun - I don't know how I got by without it before.
