Full Paint Job
/ Full Paint Job
/ Full Paint Job
I'm done. Here's the finished paint job.
There was some earlier discussion about 5 ft. & 10 ft. paint jobs. I used a brush & roller for all the painting - mostly touchups. I call it a 20 ft., candlelight, 20/100, paint job - best viewed from 20 ft in dim light without your glasses.
At least all the metal is protected.
/ Full Paint Job #45
What brand of paint did you use?
thanks,
reed
/ Full Paint Job #46
The pictures look good. I looks like a professional job. You are probably the only one who is really going to look at it up close, and as you said, at least the metal is protected.
/ Full Paint Job #47
Excellent results!
later
/ Full Paint Job
thanks,
reed
Kubota Orange from Carquest (their part no CFP 4707-GL). $45 / gallon. Good match. I started using rust oxide colour primer but found coverage was much better over grey primer.
/ Full Paint Job #51
It looks pretty darned good to me no matter how you did it.
/ Full Paint Job #53
Kubota uses a light tannish color primer. So you were wise to switch to a lighter color. Kubota doesn't use light primer to lighten their color, they do it for easier coverage with less paint.
Good job. I like how you detailed it including adding stickers. Very professional from my seat. And very time consuming!!! :thumbsup:
/ Full Paint Job
Not time consuming - all decals are original. I just painted around them.
/ Full Paint Job #56
Have you figured out where to put a tool box on this tractor yet? After many weeks of thinking about it, I have a plan but it won't work with a backhoe. Not a problem on mine.
/ Full Paint Job
I haven't really thought about a tool box but it sure would be useful. I expect the backhoe will be on most of the time. Anybody have a suggestion?
/ Full Paint Job
I thought I would give the machine a try at home before its one way trip to the cottage. I cut a cedar bush down last year leaving the roots. Last fall I bought a thumb & finger from Brotek. I haven't used the thumb yet but this gave me a chance to give that root the finger.
/ Full Paint Job
I'm finally putting this little beast to work. Lots of fun - I don't know how I got by without it before.
48" Farm Jack (A64127)
12T Shop Press (A66408)
12T Shop Press...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
Rotomec Auger (A64127)
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
2022 EZ-GO ELITE...
