665 same frame as 545?
/ 665 same frame as 545? #1
Zenostone
Howdy. I ran across a deal on a loader for a 665 - does anyone know if it'll bolt up to my 545?
Also thinking of buying a Bush Hog loader if the 665 loader doesn't pan out. The dealer said I'll need a "Hydraulic Block Kit" Anyone know where i can order one - I do have a set of remotes on the tractor.
Thanks in advance.
Russ......
/ 665 same frame as 545? #2
Thanks in advance.
Russ......
IF that loader dosn't work on your tractor got a 675DTC that loader might work on let me know I might be intersted Good Luck
/ 665 same frame as 545? #3
A 545 and a 665 2wd tractor took a model 5345 loader. They also listed a 5245 for a 545. It was alot lighter loader. I would suggest careful measurements before purchase. You can put any loader on any tractor with effort. I do have specs if you want to pm. me Trac
John Deere Z994R (A60462)
John Deere Z994R...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
159118 (A60430)
159118 (A60430)
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2019 John Deere R-4038 (A63688)
2019 John Deere...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
