Chipper Home made Chipper Shredder - Sheeps foot
/ Home made Chipper Shredder - Sheeps foot #11
allways wondered if an old corn grinder would work for a chipper/shredded. Found one awile back and passed it up because I wasn't shure.
/ Home made Chipper Shredder - Sheeps foot #12
Yes i put a 1" thread plug in the tank and plan to fill it with water when i get it to my lot. I didn't use sand because i will have to trailer it back and forth from the lot to the house and this way i can take some weight out of it. I think sand would be a better choice as it would weigh a lot more.
Brian
A gal of Quartz sand is only 1.2 times a gal of water weight.
/ Home made Chipper Shredder - Sheeps foot #13
Yeah, but he can drain the water out after use...his post did mention that his FEL could barely lift the empty tank. Of course, that doesn't mean his 3PH can't.
/ Home made Chipper Shredder - Sheeps foot #14
My chart shows sand at twice the weight of water.
/ Home made Chipper Shredder - Sheeps foot #15
Maybe wet sand. This was extracted from an article.
When you weigh a gallon of sand, you are weighing rock particles and the air space between them. If the gallon container was somehow filled with pure rock with no air space in it, it would weigh:
density of typical sand particle, mostly silica: 2.65 grams/cubic centimeter (g/cc)
1 gallon = 3785 cc
3785cc x 2.65 g/cc = 10030g = 22 pounds
But sand does have that air space in it, and it's weight will depend how closely packed the sand particles are to each other. A typical density of loose sand is about 1.6 g/cc (called "bulk density," because it includes both the sand particles and the air space). So:
3785cc x 1.6 g/cc = 6,056g = 13.3 pounds.
/ Home made Chipper Shredder - Sheeps foot #16
I know hindsight is always better but I would have staggered the rows. I hope there is no bouncing between the time one row contacts the dirt and then the next row. staggered it would be in constant contact.
Simple Answer is NOPE. :thumbdown:
But you should have got the corn grinder anyway. :drink:
/ Home made Chipper Shredder - Sheeps foot #18
Yes, I agree that water would be the best medium all around, but sand would give the most weight per volume.
/ Home made Chipper Shredder - Sheeps foot #19
you are right, there is a slight bounce between rows. . .And i'm mad at my self for not seeing that before i started welding. I was on my 3rd row when it hit me. I,ve only pulled it empty and only about 50'. The bounce isn't that bad but i'm sure after i use it the first day i'll be looking at a way to fix it.
Shredder Thoughts
Would like some thoughts on using the front hub, brake rotor, axle & spindle off a front wheel drive.
In a heavy steel box mount spindle, axle out the back. Weld shredder spikes to rotor and fashion a feeder chute. 5 To 10 HP. engine. Direct drive, chain or belt drive, clutch or no clutch.
What you think??:confused::confused::(
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
24220 (A56859)
24220 (A56859)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
