JD 2520 Snapped Axle
/ JD 2520 Snapped Axle #1
AengusMacloughlin
JD 2520
I was clearing brush for a new neighbor with my 2520 (160 hours) when I heard a pop and gushing sound. I shut down the tractor and checked out the back, where I found hydraulic fluid gushing from the right axle hub, the right wheel no longer perpendicular to the axle centerline, and black plastic mesh wrapped around the left axle area. Four wheel drive was engaged. My guess is that the left wheel siezed due to the mesh, the right axle snapped and the tire was dragged sideways, producing a trench seen in the photo. I would like to get a more substantial tractor but I have a lot invested in this one, including the 200CX loader with 2 buckets and the 62D mower. This will be the 4th and most substantial repair, having once sheared a drive gear on a front wheel, and twice replaced the outer drive gearbox housings on the rear wheels. I purchased a Deere because I believed in their reputation as being customer oriented and having quality products. I don't think I abuse my equipment, nor that plastic mesh should be able to snap an axle. Do you think I have a "lemon" and should seek remediation with my local dealer?
/ JD 2520 Snapped Axle #2
From what I could see here that plastic may not have had anything to do with the right wheel!! I have a 2720 and have always thought of that rear wheel set up as a weak link. I am used to seeing tractors with a straight wheel shaft, rather than what must be an offset gear box. I am sure this is the HST set up but it looks weak to me for carrying as much load that these tractors can put out. Would really be interested in what you find out from your dealer as being the cause.
Wooden
/ JD 2520 Snapped Axle #3
That mesh didn't cause any problem. That had nothing to do with it.
It looks like the final drive housing broke not the axle. The axles on these tractors are a short stub shaft , that is what puts so much stress on that final drive housing. the amount of leverage especially with heavy weight on the three point is crazy.
Were all of the bolts in the final drive housing? you said they have been repaired before, i'd say your bouncing to much weight on the rear which is what is breaking those housings..
/ JD 2520 Snapped Axle #4
Ditto on the mesh not being the cause. If it had locked up the left wheel the tractor would have tried to turn sharply to the left.
If I had a break like this, I would move up in tractor.
/ JD 2520 Snapped Axle #5
With that many issues in so few hours, perhaps you are expecting a bit much from this tractor? I've accumulated 2600 hours on a 655ZTak, a 755, and a 3320. Failures? I caught a piece of baling twine and ruined a wheel seal on my 3320.
While there are some who will advise you to run a hydro at max rpm, I am of the belief that you run it at what is required to get the job done. I notice you have a box blade. were you running at high RPM and suddenly the box blade caught something substantial? Shock can be a killer. I would think that a hydro might be a bit more forgiving, then again who knows-and as someone has pointed out, your final drive is a bit complicated-maybe "weak" is a better word. In any case though, it should be designed to handle any implement that fits.
Good luck with your dealer. Suggestion- give it a good cleaning before the dealer shows up. Some guys like to hang there hat on anything to claim "abuse". Don't give them any ammunition.
/ JD 2520 Snapped Axle #6
I suspect you bought too small a tractor for the tasks you want to do.
Four repairs in 160 hours would wave a red flag in my eyes (for any tractor, not just the 2520), so don't be surprised if the dealer does balk...I sure would.
The 2520 has been around for a while and there has not (to my knowledge) been reports of similar failures on TBN so I don't think we're seeing a design issue.
/ JD 2520 Snapped Axle #7
I'd be willing to bet there was a more catastrophic event prior to getting mesh wrapped up (that had no effect in my opinion).
I don't think you have a lemon, but strongly suspect you don't have the tank that you need to do the kind of work at the pace you are going. Abuse? I'll leave that up to you.
I also wouldn't expect Deere to cover it, but I would not be surprised that they would. Backing up their product has long been a trait of Deere.
I bought the 2520 because the next bigger tractor was a thousand pounds heavier. I was concerned about too much weight when mowing and driving over my sprinkler heads. I was using the box blade scarifers as a rake to pull up thorn bushes, so there really wasn't much stress on the back end. I think the engine was at around 2200 rpm, and I had driven through the same area several times before without snagging any immobile objects. I'll go look around and see if there really was something underground. Thanks for the input - it's theraputic to discuss this with knowledgable people. I'll go get my box blade and use a Chalmers 5030 or David Brown 990 to complete the cleanup.
/ JD 2520 Snapped Axle #9
FWIW...this is sort of related...
It does not take very much monofiliment or braided fishing line to render any single screw vessle dead in the water...
...I have seen fishing line force the wheel right off a 1-3/8" SS shaft...stripping the threads and pushing the nut right off...likewise with cutlass bearings and struts...the force can be extreme...
/ JD 2520 Snapped Axle #10
i believe what your saying, but i'll bet anything that mesh on his left axle had NOTHING to do with this breakdown.....
something is being done to this tractor to break these housings...i had a 2520 for 100 hours and abused it pretty hard but never broke any housings, but i remember looking at them thinking they are a time bomb if you have a heavy load on the three point.....
/ JD 2520 Snapped Axle #11
So what caused the rut on the path leading up to the ginked wheel? It looks to me like something pushed or dragged the tractor sideways in a turn and that force caused the axle to snap. Is there more to this story?:confused2:
I cut the mesh off the left wheel and now don't think that caused the problem on the right. I've had baling twine and steel fence wire wrap a rotary tiller and a rotary mower, so I respect what binding forces can do to steel and bearings. The mesh wasn't wedged deep, nor very tight. I did notice hydraulic fluid at the beginning of the rut, so I think when the failure occured, the tire went off-axle, and it was the tire dragging sideways that caused the rut. If there was excessive force cause by the box blade, I think a failure wouldhave occured in the lift arms or top link or their attachment points, and not on the wheel. I don't remember being in a turn with the scarifers down, but if I was perhaps this caused a side load on the wheel that caused the failure.
/ JD 2520 Snapped Axle #13
Wow, I always thought I ran my 2520 hard! You must run yours way harder! :laughing: That looks expensive.:mad:
/ JD 2520 Snapped Axle #14
Too late now, of course...but you'd be a prime candidate for a tractor and a dedicated mowing machine.
/ JD 2520 Snapped Axle #15
That mesh is pretty mean and nasty stuff if it gets wound up tight. I have got this stuff wrapped around my stump jumper on my brush of a couple of times. We're talking a hammer and chisel to get this stuff off.
/ JD 2520 Snapped Axle #16
as said before....that had NOTHING to do with the right side housing breaking...
upgrade to a 3x20 series, they don't leave anymore of a wheeltrack mowing...the tires have more of a footprint on them. there are thousands of people that mow with them, and almost every golf course ive seen has that size minimum for a utility tractor. they use them on the greens and all.....
/ JD 2520 Snapped Axle #17
I am not disagreeing with anyone but for a tractor to break an axle housing something drastic had to have happened. Just pulling a heavy load or working a tractor hard shouldn't have caused this to happen.
/ JD 2520 Snapped Axle #18
The admitted fact that there have been 4 breakages in this tractor's 160 hours indicates something.
Since we don't know the OP or the circumstances other then what has been posted, none of us can really speculate on these failures...but my opinion stands...too little a machine for the tasks being performed.
/ JD 2520 Snapped Axle #19
A brand and size of tractor is getting a bad rap here for reasons we don't know. It almost sounds like these smaller tractors can't cut the mustard under a heavy load. That they will just disintegrate with heavy use. That has not been the case in my experience.
/ JD 2520 Snapped Axle #20
agree 100%
i had a 2520 and used it pretty hard and never had a problem. i had all kinds of heavy crap on the three point bouncing and never had such a problem.
Is there a back hoe we don't know about on this tractor ever??
