Murray engine troubles
/ Murray engine troubles #1
handirifle
Central Coast of CA
Massey Ferguson 1010
I just bought (yesterday) a Murray riding mower from a private party. The guy said he had just spent $200 on maint items, plugs, new battery even new brakes on it.
I tested it and everything worked fine. Engine had a little pop every now and then, but so does my Husqy push mower, so no biggie. Plenty of power etc. So I bought it. Took it home and got about 75% of my 3 acres mowed, when it started backfiring, and wouldn't fun below half throttle.
It's a 20hp Briggs n Stratton, engine mod 460 777 type 1877 A1, and I already did some research on it. It is the opposed cyl engine, not a v-twin. Pulled flywheel nut to look at keyway, it looks perfect. Then I did a compression test. The cyl on right (passenger) side has about 100lbs, but the left side has ZERO.
What's the most likely culprit here? I didn't hear anything sounding like it broke, and nothing rattles.
What's a rebuild likely to cost?
/ Murray engine troubles #2
QUOTE:
"What's the most likely culprit here"?
One of the valves on that non compression cylinder is stuck open.
Well, you're partly right. After posting I went to a local mower shop and spoke to a guy there, and he told mea bout a possible stuck valve. I purchased some penetrating oil to use to "unstick" it. So I went home, pulled the head, and both valves were closed. Hmmmm
I pulled the other plug, and rotated the crank to watch function. Seemed normal, so I thought I'd spray someup towards the guides, just in case one had a tendacy to stick and this would help.
That's when I discovered the REAL problem. When I stuck the spray tube into the valve area, a little ring fell onto it. As I looked it over, I realized it was the valve seat, for the exhaust valve. Another call to the repair shop, the guy tells me I should be able to just put the seat back in place and peen the cylinder around it and it would stay in place.
Well back to the engine and the darn seat doesn't seem to want to stay in place. Looking a little closer, I see a shiny area at about the 7 o clock position around the seat. A closer look at this area and I see an egg shaped area that can't be good.
So I pulled the other head off to compare, and it was what I feared. The valve seat has beat the crap out of the area it's supposed to stay in. Being a flat head engine, this cylinder is shot.
Anyone know what my options are? Can I get a replacement cylinder? A new engine is at least $550, and that is a lot more than I can spend right now. I paid $500 for this thing two days ago and it looks like I'm going to spend quite a bit more to fix this.
/ Murray engine troubles #4
Possibly a mouse nest under the shroud caused too much heat. Maybe it's time to see just how good JB weld is. Clean it good, apply enough to fill the egg cavity, place the seat in the hole and then install the valve so it centers the seat concentric with the valve. Not much to loose but time. I know a fellow that filled a grooved piston with JB and it ran a long time.
I suspect many miles separate us but I have an opposed twin engine in a craftsman you could have.
Well when I pulled the shrouds off there was a ton of crap in there. I blew that all out, first thing. I knew it wasn't doing the engine any good. Looks like it did it worse than I suspected.
Depending on what my options turn out like I just might try the JB. The big problem, is, it looks like the valve seat chewed up the entire exhaust chamber and there may not be enough to weld it to. It's a real pisser.
By the way, I live in central coast of CA. Is yours a 20hp?
/ Murray engine troubles #6
Join the club..I bought a Murray rider years ago.2 cylinder B&S 16 or 18 Hp (I forgott which) the guy said it ran like a top and it did sound good.after paying good money, and using it for about 45 minets it started backfireing I also had "0" compression in one cylinder and found the valve seat had been beaten to death.the valve and seat are part of the crankcase not a replaceable head. I took it all apart and went to a local machine shop. they wanted a ARM and a LEG to clean up the hole and insert an new seat and then would not gurantee it would last. I took it all back gave everything to the local scrap guy for metal scrap.(you ain't the only one who gets screwed!). If you like the mower get a replacement engine. If not cut your losses and dump the whole thing!( he probably Jurry rigged other things on the mower tooooo)
Well I talked to a repair guy and he told be basically what you just did. I knew the valves were in the cylinder, but figured the cylinder was replacable. NOPE. He said the cylinder is part of the block assembly.
I have found listings of replacement engines for this model, out of stock, but they list at over $1500????? All this for a $500 mower!!!
How much was the ARM and LEG exactly?
/ Murray engine troubles #9
That information is posted on nearly every gas pump.:laughing::laughing:
/ Murray engine troubles #11
Google "small engine warehouse" and check their prices if you want to purchase new. I would check Craigslist and any local flea markets for a good used engine. There are quite a few around. There isn't anything special about the engines that Murray used and you should find any number of other engines compatible.:thumbsup:
Jim
If you mean the $3.70 a gallon we pay here, I'd gladly pay that for an engine.
Jim
Well I checked with SEW and theirs were all over $1000. I have some ideas about trying to fix it. Not much to lose at this point if it doesn't work.
I'll try to see if I can find a machinist that can fill weld it where the seat goes, and machine it out to accept a new valve seat. if that fails or is cost prohibitive, I'll try a coule go for broke ideas I have. I will take pics to post, in cast it works. Maybe can help someone else down the road.
/ Murray engine troubles #14
I don't know which engines you're looking at, but there were over 400 19.5 horse Intek I/C B&S engines for $510.
Jim
/ Murray engine troubles #15
The arm and leg back then was over $185.00 to machine it and press in a seat.with no gurantee.I then offered one of the "wife's" legs..The price went up!! go figure.
Jim
I was looking at 20hp engines. I know there doesn't seem much difference from 19.5 to 20. but this engine is 750cc and all the 20hp engines around now are 600cc. Mine is rated for commercial use and is a very high torque motor. I do not really want to give up the torque, if possible.
I went back and did a search at SEW for a 19.5hp engine and got 3???? When I put in 20hp I get about 50, but over half are over $1000 so not sure what I'm doing wrong or different there.
Mark, $185 is cheap, to me. I'd pay $200-300 to get this fixed, that would be a lot better than $600 plus.
/ Murray engine troubles #17
Well $185.00 might seem cheap now but several years ago it wasn't..and you need to remember that's just for the machining work. I would still need to buy a valve,seat,complete gasket set. put it together,etc.Then while waiting for a estimate from the machine shop I found a bunch of other "Gems" wrong with the mower.I found he musta had a deck spindle that he stripped the nut on.so he WELDED the blade on,etc. I would scrap the whole thing today if I had to do it over again.too
Well yours doesn't sound like mine, actually. I do believe this guy had no idea it was coming. He had just put new brakes, new battery, and new blades on this one, and gave me a set of new blades to go with it. I do not think he would have gone to all that trouble if he knew it was that close to breaking. Sorry yours was scrap.
I have a friend of the family that is a welder with lots of experience with aluminum, and I will machine it back down myself. I am going to try and just pull those two valves, and not disassemble the whole engine, if possible.
If this idea doesn't pan out, then I'll replace the engine. But this will lost me little or nothing, so I have to try. In the mean time I'm gonna start saving for this one. It's the one I really wanted, but couldn't afford, so I will have to wait I suppose. At $3000 it's pricey, but heavy duty.
/ Murray engine troubles #19
Go back and find out who had an engine and was willing to give it to you... Pay whatever it takes for him to ship it to you... Sheesh!
/ Murray engine troubles #20
Recheck your model #. A 27 hp engine is only a 44xxxx series and you listed yours as a 460777 which suggests that your engine is larger. As I recall, the first numbers indicate displacement in cu. in.
Jim
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
