Small bridge project
   / Small bridge project #11
Great project.
Add me to the list of those want to see more pics and updates!!!!!!
I day dream about building bridges. I'll probably only build one across my spillway, but I think about all sorts of places I "want" to build them.
It look like a VERY FUN project.
Thanks,
Eddie
Eddy,
Went by your place last night about 12am to a small job in Longview.
Here is a couple of photos. Last one is poor, almost dark.
1st one shows 2 of the pipe cross supports welded in with the I-beam welded to the piers.
2nd one is the first few pipe cross overs welded on. We went 12" since my neighbor has decided on the steel catwalk material for deck. This will be a "stout" sucker for sure. Total weight of the bridge will be between 2000-3000lbs approximately.
I have told my neighbor about TBN, Hope that "city slicker turned country boy" joins in the ruckus. Hey! even has overalls so he should fit right in:D
Duh! forgot the photos in the previous.
   / Small bridge project #14
I'd probably tie a chain to a nearby tree so it does not float away.:laughing:
I have a low area with a concrete culvert. Its about a 100 foot causeway. Some day I am gonna make like a train trestle. I remember my dad making a bridge over a bay at the cottage. We had fun for years playing on it.
Funny you say that, I was kinda hoping it would "float" over to my side of the fence since possession is 9/10ths of the law. I think tomorrow I will weld 10, 55 gallon drums under it, what do you think?:D
Below is a photo of my "culvert" project from 5 years ago.
I had a County road guy stop by and give me advice on a culvert, also had the help of the bulldozer operator who has put in ALLOT of them.
Since I had such a steep approach from one side I went with a 48" culvert. The dozer operator pushed and pulled dirt to try and mix what little clay I had to build up a base. We placed the culvert and then started with the dirt, 6" increments then water and rolling, (My place is sandy to a sandy loam.)
After that I formed the top and apron with 1/2 re-bar set at 16" center with cement at 8" ( I wanted to be able to take a full cement truck over later) The day after the pour it started to rain, we got almost 15" in 4 days. We where flooded, heck ft worth was flooded. It was 3' over the culvert drive. I am not in the 100yr flood plain and this event will likely never happen again.
And so it sits, my $6500 gorilla. This creek isn't much till it get's aggravated.
   / Small bridge project #17
The multiplier in deciding the bridge was not $$,but reliability.
On a perfect day I would have wanted full concrete abutments on both ends.
I don't think there is a "perfect" way to cross a creek, each situation is different and requires a little "tweaking" to accomplish the same goal.
The culvert I installed (pic in an earlier post) actually replaced a small wooden bridge that wouldn't support a tractor or truck. I considered a replacement bridge but in discussions with the county when I called for a permit, I found that a culvert would be cheapest and easiest and much preferred by the County with jurisdiction over the Drain I was crossing. Took all of one day to complete and a lot of that time was sitting around waiting for the culvert delivery or admiring the completed job.
As for reliability, I would dispute that a bridge would be any more reliable than a culvert. If the water gets to be 8' in that creek, it's going to cover both types of crossing. I wouldn't worry about full abutments either, maybe some rip-rap, which I installed on the upstream side to prevent any erosion (just happened to have a pile of broken concrete laying around):thumbsup:
You're right, each situation is different. Further downstream, I'm considering a crossing where the creek is closer to 10' deep and that will probably be a bridge. It's just for people and horses so a couple of oaks may just "fall" across the creek one day. ;)
Anyway, have fun on your project.
JML,
Thanks for your input, I wish now on mine I would have used rock instead of my native sand, but was assured buy the a fore mention crew I would be fine, go figure.
As far as reliability, I may have posted that with the wrong meaning, We are "overbuilding" the bridge for reliability, not that a culvert would be less reliable if you don't mind an occasional water crossing.
   / Small bridge project #19
I thought about using a bridge on our driveway but culverts worked out to be the better way.
I used 36" cement culverts that come in short sections and each one has a bell for another to fit into. I placed 30# felt over the joints.
This has worked for 30 years as our main drive.
I recently used some more of them for a drive that across a ditch that runs through our property. (we had extras we kept for many years)
The best part - the culverts were free. They were left over from a building that my Dad worked on.
Had some time to add to the project.
We got the center I-beam in, little of the top deck and the approaches cut, welded and concreted. We still need to build the center beam forms and pour around the center columns.
Unused Delta Crash...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
LOT LOCATIONS (A51219)
John Deere 693 Corn Head (A50514)
John Deere 693...
