nortrac dozer trouble
/ nortrac dozer trouble #21
ultrarunner; Thanks for the input, I'm wondering if the water froze and caused some unseen damage inside? I'll try the brake cleaner thing 1st and see what happens, if that doesn't work, then when I tear it down I'll try to get some pictures and post what happened.{if i can work the camera :confused2: :laughing:
Moisture can and does cause the friction material to bond to the clutch plate and flywheel...
Members with antique equipment in dry areas of the country seldom have this problem... some of the guys in Western WA block the clutch pedal down when the machine is not in use to prevent it.
I'm still wondering if the friction material separated and overlapped since it was working.
When this happened to me, the clutch had more free play put the pedal was not loose because the return spring was still in play.
Bob Rocks if/when it comes time to tear it apart I'll check into the local shops.
Sound more and more like there really is a problem internally.
That's what I figured from the get go, just wanted some other ideas opinons :thumbsup: And in the end maybe even help someone else that comes here?????
If your clutch plate fell apart and is doubled up making it extra thick so it won't disengage then you would have suddenly had excessive free play in the clutch pedal, did this happen? Did it have little free play when it was working then suddenly have more free play when not working?
stayed the same
When you press the clutch, do you feel the same tension now as you did when it was working?
yep, the only thing that changed is it doesn't want to disengage{erratic function may be a better way to explain}. I did take the plate off to watch the action{as best I could see} and everything seemed to move the way it should. It's still hard to see things real good in there but if I hold my head, flash light, and face :laughing: at just the right angle I could see the release bearing bracket move. From what I could see things seemed good except the nasty water. Also sounds normal
If you take all the free play out, you should press the clutch and feel the spring resisting you more and more up to a point where you over extend it, then it should become a little less resistance.
I have it adjusted so far now that it will hit the housing, feels the same once it gets out of free play, free play is about an inch.
It is all about feeling, I would try to get a friend (that is mechanical) to put a fresh set of eyes and hands on it for another opinion before the hassle of taking it apart.
I don't have any friends :D Actually I live off the beatin path not many folks around. The ones I do know are allways busy unless of course they need something from me :( :) I have rebuilt trans before even a couple of automatics out of a jeep and old chevy PU. I figured I'd have to tear this down I just wanted to make sure I remembered all the little {easier} stuff 1st. This site has helped in the past with ideas and a different way to look at something so........here I am again :)
Note: I think the whole shear pin in the clutch linkage anywhere is just a poor design. Cars and Trucks do not use them, the linkage is all solid and there is no need for a weak link. The clutch on a tractor has no special needs that would require a weak link. If the clutch were to jam the weak link should be your foot feeling a problem and not mashing it.
I agree, but whom ever designed these doesn't. I take it you were raised the old fashioned way around machines, "listen to them and they'll tell what is happening". I was taught this and I have also tried to teach my kids the same. Even though I feel that is a good way to be taught it's not the norm for today, so maybe that's why they designed the shear pins?
Note 2: If the shear pins inside are going to fail, they will regardless of what is going on outside. My shear pin was failing just from normal use, so I got rid of it.
Is it possible that it{your outside 1} failed so that the inside ones{2} wouldn't, just a thought.
If a situation arose where the clutch jammed and you applied excessive force to the pedal which sheared the pin on the outside and saved the pins on the inside... what good is that?
The good of that is that it's much easier to fix the outside pin compared to tearing the machine down to get inside :confused: especially if it's just from wear or actual design.
You still need to open the tractor and find out what jammed the clutch.
I answered your question to quick sorry :eek: :eek: you are correct if it was jammed, then before anything sheared/snapped maybe it should be torn into?
The only thing I can figure is the design of how it works. Your outside shear broke because of normal wear which inturn probably saved the inside pins. Now if you make the outside stronger then the in, then the inside will shear before the outside. Hope this helps clear up what my opinion is and how I see THEIR design. Remember it's their design not mine and I understand what you're saying, but when modifying something it will still only be a strong as the next weakest link, in this case the inside shear pins.
So in my case, I would shear the pins on the inside and just weld those up while I am in there fixing the clutch.
I had allready planed on reinforcing the inside pins :thumbsup: Once I relized I may have to tear this apart and saw those pins{in the manual} I figured I'd fix/reinforce everything even the crappy shear pins{even if there is nothing wrong with them}.
If the clutch is working normally and the pins just failed because they are cheap and weak, that will happen no matter what is on the outside joint (be it a working roll pin or a bolt and tack weld).
Here is where I'll disagree atleast to a small extent. In this case we have 3 shear pins 1 outside and 2 on the inner. If they're all made the same then the 2 fixed to the clutch release fork would be twice a strong as the 1 connected to the clutch release lever. I do agree they are all somewhat cheap and if anyone has to tear into this type of machine then they should modify all 3 :) Of course sooner or later the inside ones will fail because of design, maybe by that time you'd allready be there needing a new clutch?
Note 3: I am not pushing anyone to weld the linkage, I am just arguing the need for a "weak link". Weak Links are used in areas where overload is possible and protection is needed. There is no reason for clutch pedal overload.
Gene :^)
I agree with what you're saying, but just remember modifying one part of a unit still only makes it as strong as the weakest part of the same unit. If a weld, bolt, etc... is going to be used then IMO other mods should be done also. When I redid my shear pin on my tractor I did upgrade to a stronger pin, but still gave it room to do what it was designed for. I'm not disagreeing with your opinion just trying to explain what I feel the design is and what may happen.
Thanks agin everyone for your insights, I'll keep ya updated as to what happens. I'm also going to try the wash out trick, but not really going to get my hopes up. I'm thinking something snapped or twisted out of shape. I did mention the water and we have been down to 27 below 0 F. Water is a power of mother nature that can destroy when it wants. If nothing else I have learned there is a weep hole at the bottom of the clutch housing{it's small} and it should be check regular right along with the nuts, bolts, track tention, oil filters, grease, and ....... and ..... and...... oh the joys of owning machinery :D :laughing:
The more I think about it my gut seems to say something happened because of the water. I feel stupid for not finding that weep hole earlier it probably would have prevented this from happening. Blocking the clutch may be a good idea, I just wonder if it may have a negative impact on the springs{make them weak} down the road? thanks again for the help/ideas/opinions :thumbsup:
/ nortrac dozer trouble #24
I will take a guess: The clutch plate center spline is rusted to the shaft spline and when you depress the clutch you are only pulling the pressure plate off of the clutch disc, however the other side of the clutch disc is still up against the flywheel and slips due to flex but the heat from slipping makes it start grabbing again.
Gene :^)
/ nortrac dozer trouble #25
Gene :^)
seems like this could be part of the culprit, I have a EXP setting out back that had similar happen, drove in winter blew brake line and parked it untill spring. first clutch depress the rusted input spline grabbed the disk & would not let it return once it released.
Mark
/ nortrac dozer trouble #26
Could the clutch disk have slipped and overheated and warped? Alot of old backhoes with clutches like my old 3550 Ford have done this. Even standard ag tractors with loaders. Its hard to catch this sometimes as it takes a very little warpages to make on drag like that. I was looking at a clutch disk for splintered, and overlapped parts. I had an old man tell me about the disk being warped and sue enough with an indicator we found a big warp in it.
thanks for all the ideas, I still have not had a chance to try the brake cleaner trick yet, maybe today. As soon as I can try it I'll post my results.
/ nortrac dozer trouble #28
Yes, I don't know what I'm talking about:
yet there springs up some intuitive "feel" to this thread
which reminds me of "warped clutch disk facing"
in a hot-rod Chevy I once built.
The facing material in the liteweight flywheel
had been abused enough to warp out enough to drag a bit,
even when disengaged.
The first few shifts were ok:
but soon the projecting facing would get hot and expand more,
and drag more, and expand more..
and pretty quickly you would have the situation you describe.
(Never should have put a lite flywheel behind that 301.6 ci smallblock
anywho..)
/ nortrac dozer trouble #30
"inquiring minds want to know"
The weather is still nasty, going to be 30 today {most of the weekend} but windchill will seem more below 0. Last week I was allready to get it out and start tearing it apart we hit high 30s-40s{beautifull weather}. Then I remembered where I live and that it is only march we have been getting rain snow sleet and just plain crap weather. I am hoping to get it out within the next couple of weeks. I'll try to post pictures and what has happened. I have to do the work outside because my garage is not big enough.
Just a simple update, started pulling things apart, been kind of a pain working on it in between nasty weather. I'll try and get some pictures this weekend. Today I hope to have it spilt just trying to figure out the best type of hoist. I was going to use a mini excavator but figure I'd like a little more control and be able to see what I'm doing. I'm not so worried about splitting as much as getting it lined up and back together.
/ nortrac dozer trouble #33
FYI, a gantry crane works best, even outside with heavy plywood to roll around on.
Hey Bob Rooks :)
Well I got it apart used the mini ex it was nice and easy with no problems, just took my time. I'll probably try to get some help lining it back up, the mini seemed to do okay. Well things didn't look horrible just rusty and covered in clay film{expected it}. I did get some pictures hopefully I'll get them on here in the next couple of days. I believe my problem was that I tore out the throw out bearing, the clutch didn't even look that bad. I did order all new parts{allmost $500.00} rather do a complete job and have piece of mind.
Parts came in yesterday not sure when I'll get back to work on it, snow rain and miserable weather today. Still looking for the cable to connect my camera so I can show some pictures :confused2:
Hey folks I believe I have some pictures to share
Looks like it worked computer is slow, I have a couple more I'll post later.
As you can see the muck really caked onto/in the clutch housing. I did get a chance to work on it some, cleaned and replaced many parts. I do have the engine back into the machine, now I have a "bunch" of nutz and bolts to put back along with gaurds, front nose, radiator, etc...
/ nortrac dozer trouble #39
Great pics :thumbsup:. Not bad for working in the field (brings back memories). Curious how long the tractor had been apart when the pics were taken?
Noticed what appear to be heat checks on the flywheel. Did you resurface it?
I didn't resurface the fly wheel, do you think it will be an issue? I did clean it up and everything seemed okay. Even though I have not started the machine yet I did have my son push the clutch while I turned the PTO shaft{while engaged}. Once the clutch was let out I could not turn the shaft. Before I did the repair I could not turn the PTO shaft even with the clutch pushed in. Everything went back together with ease once it was aligned. Hopefully I'll be able to finish tomorrow, possible break in the rain, might even have this thing they call sunshine :D. The engine was out of the dozer for 5 days I took the pictures right before I started cleaning and fitting everything back together.
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
Cattle Feeder (A65640)
40ft Shipping Container (A64194)
40ft Shipping...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
John Deere 4040 Tractor (A64047)
John Deere 4040...
