Loader Bent loader arm at sleave for pin
   / Bent loader arm at sleave for pin #1
jsranman
Member
I have a 2006 B2630 with a LA403 loader that I put a plow on. The plow is attached to the loader arms and cylinders with a steel bracket that has tabs on it that you use to put the loader arm/cylinder pins in. I was moving a tremendous amount of snow with it this winter. I have a 1000 foot driveway plus I did a neighbors driveway and helped others out from time to time when they were completely snowed in.
Somewhere along the line while plowing all this snow we had this winter, a pin fell out of the loader arm and I did not notice it. The plow remained attached via 3 other pins (one through the other loader arm and two through the cylinders). In the process of plowing without the fourth pin the steel on the loader arm where the one pin remained and where the sleave for that pin is got bent. At this point I cant tell if anything else is bent. I just cant tell by looking at it. I have a bad feeling that other things are out of whack though. My bucket is inaccessible up in the woods under the snow so I cant check to see if everything lines up by seeing if I can connect it.
Any advice as to how to diagnose any remaining possible problems and fixing the bent arm at the sleave? I am thinking I need a welder to cut it out and reweld it in at the proper alignment?? I will put some pics up as soon as I figure that out.
[/ATTACH][/ATTACH]
   / Bent loader arm at sleave for pin #3
You can do some point to point cross measurements to check if the arms are wracked out of parallel...
The twist that an angled blade puts on the arms is sometimes quite high.
If everything will still pin up, I would leave will enough alone. If it is tweeked too much for alignment, then you might have to either heat and reshape or cut and reweld...
If it is off a little and is off being perfectly true, I would not worry too much as there are some new loaders that are not exactly true and plumb...
If you can not re-pin the bucket, then you may have to do something... In any case you should repaint the injury/repair to prevent rust from further degrading the strength... KennyV
   / Bent loader arm at sleave for pin #4
Kind of hard to tell how bad it is from the pictures. If it were mine, I would find a piece of cold rolled steel shaft as close to the pin size as possible , but still fit through the arm. Slide that through the bent side and see where it lands on the good side. You can probably straighten it using a rosebud on a torch and heating it bright red and using a long pry bar through the pin hole to pull it back straight. Use the cold rolled only to check your progress. You would want to do most of the heating on the side of the arm that is bulged. Flattening the bulge with a hammer may help too. You'll also need to verify that the distance between the arms is correct. It could also be done the way you suggested, cutting and welding. I would still use the cold rolled for an alignment tool.
Kim
   / Bent loader arm at sleave for pin #5
I wouldn't use the cold rolled for alignment if you cut and weld unless it is a tight and perfect fit. Even a small amount of play gets multiplied substantially. I speak from experience, used this technique on an older case and the bucket has never fit quite right since. It's important enough to get it right to make the effort to dig out the bucket so you know the alignment is right. A carpenters square can also help you figure out if other things are out of whack.
   / Bent loader arm at sleave for pin #6
Go talk to the local heavy equipment dealer. They have alignment bars and tools to align bore pins and internal welders to build to bore up. They also can bore and sleeve with bushing to bring the pins tight again.
   / Bent loader arm at sleave for pin #7
I friend of mine just fixed a big loader arm for the same reason - pin fell out and they kept using it. He put a long bar through the bushing hole, then loaded the arm using the hydraulics - I think he used a snowplow to rest the other end of the bar. Anyway, the front end of the machine came up off the ground, with corrective pressure on the bar. He then hit the arm with a rosebud-equipped torch. Sloooooowly, the arm twisted back into position and it was fixed. Took an hour all together.
JayC
   / Bent loader arm at sleave for pin #8
I don't think many equipment dealers are going to have that capability. The shop I work at does that and anything less than about 1 1/2" diameter is about impossible to weld up and align bore. I agree that the cold rolled needs to have a close fit. You could use shim stock to tighten it up. I also wouldn't cut it clear loose if that is the plan. Just cut enough to be able to bend it back into alignment plus a little so when you weld it back it will draw it back.
Kim
Thanks for all the advice. Although you cant tell from the pics, I bet if I put a bar through it that was long enough to reach the other arm, that the bar would be between 1' to 2' from going through the other hole. It aint gonna pin up without some adjustment.
I am thinking plan A will be to get a some sort of bar or some type of bar/lever combination and use the hydraulics, weight of the tractor and heat to move it. I think I am going to have to heat up both sides of the arm. Its a big area to heat. I have never done this before so I am wondering if it is just too much steel to try to get soft with heat.
I know this took a lot of force to bend in the first place. The other side of the arm (not in the picture) is buldged out. There was lots of torque on the angled plow and I hit some big piles hard. I hope I can apply the necessary force to get it back.
Plan B is call the shop to come pick it up as I dont have a welder.
A couple more perhaps stupid questions: What is cold rolled? I am assumeing it is a 1" round bar that is not as straight and as a precise diameter as a pin?? What is shim stock and how would I use that?
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
Rooster Artwork (A55758)
Rooster Artwork...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
