Paint for Pipe fence
/ Paint for Pipe fence #1
UpToNoGood
Magdalena NM / Datil NM
Bobcat CT2025
I am going to be installing some pipe fence/gate next month and was wondering what kind of paint you guys use? Most of the project will be welded before I leave but the rest will be done on-site so the painting will be after it is installed.
Do you use brush/roll on or spray can?
Thanks.
/ Paint for Pipe fence #2
Thanks.
I see a Paint Mitt didn't make the top 3 on your list but you may want to check that option out.:D
/ Paint for Pipe fence #3
We used to use alkyd enamel industrial white paint when we had a whole bunch of pipe fencing when I was a kid, but we had a lot of it around work painting oilfield couplings.
Does the alkyd enamel help fight/prevent rust?
Not sure about white. I want green and the wife says black.
/ Paint for Pipe fence #5
I looked it up and it says it needs a primer to be corrosion resistant. It worked pretty well considering it was put on some pretty nasty used oilfield pipe, and being white did not help in hiding rust.
/ Paint for Pipe fence #6
OSPHO is a great primer for pipe (google), I've used it allot over the years.
I second the enamel paint and double down on the paint mitts unless you have a spray rig and know how to economically use it (fine tip).
/ Paint for Pipe fence #7
If cost isn't an issue, you can use Rust Bullet and topcoat with whatever color you want.
Rust Inhibitor Paint | Stop Rust | Rust Corrosion Inhibitor | Rust Converter
I have used it for several projects and it is pretty impressive stuff. I think it is a phenolic resin paint. Dries extremely hard and appears to stop rust. I painted part of my box blade with some leftovers and it has sat outside for 2 years. No progression of the rust in the painted areas. The downsides are cost, color and finish. It can't be thinned so it is difficult (impossible) to get a smooth even finish. It also has to be top coated within a certain amount of time or the top coat won't adhere to it. It only comes in a silver/gray color. The automotive version may be thinner, but I'm not sure.
/ Paint for Pipe fence #8
I hate hard work. So up to me everything would be painted before it went into the ground, even if final welding were not done. Then you just have to paint where the welding burns off the paint. Fairly cheap and used a lot in this part of the word is "Cool Cote". It is rubber based and 2 coats will last almost forever. Down side is limited color choice.
Better have a beer and think about this a little more. :thumbsup::thumbsup::thumbsup:
Rust Bullet was a bit pricey. But then I have to ask my self how often do I want to mess with painting. With Rust Bullet it can be done once.
$150 per gallon. Not sure how far a gallon will go. I would hate to over buy and have left overs.
So I ordered two gallons of Rust Bullet from Summit Racing. I will report back on what I think of the product. I do plan on top coating it with some rattle can paint.
Thanks for all the help.
/ Paint for Pipe fence #12
Most pipe fence around where I live is constructed from used well stem pipe and is usually pretty rusty. Almost everyone uses OSPHO on the pipe before painting. a lot of folks only use OSPHO with no paint.
I think I paid about $11.00 a gallon for mine, and it works very good. Be sure it is dry before painting though.
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2022 EZ-GO ELITE...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
John Deere 5045E for sale
John Deere 5045E...
