Fitting size
/ Fitting size #1
ffclassic
China, Texas
2010 kubota m7040 dtc
I purchased a BARE-co cylinder on Ebay and I'm not real sure on the size of the ports. I think it is an Australian company.
These are the specs:4"Bore x 18" Stroke
Shaft Diameter 2"
Closed Length 28 1/4"
Pin Diameter 1"
Ports 3/4" UN O-Ring
Working Pressure 3,000 lbs
Is this the same as an SAE 8 fitting?
I got the cylinder brand new for $97.00 including $40.00 for shipping, hopefully I can find the right fittings. I plan on using it to add a boom pole to my 3pt trailer mover.
Thanks, Matt
/ Fitting size
/ Fitting size #3
Perhaps this. Straight thread ORB to NPT.
/ Fitting size
JJ,
I found BARE-Co's website. They have an office in Sacramento but do not sell directly to customers. They have an adapter PN B3440 which isA 3/4 UNO toB 1/2 NP. I have to fill out a parts request and then they forward it to a dealer. Maybe one of the hydraulics guys on TBN handles BARE-Co? Here is a pic of the adapter.
PS, I always like reading your replies. How long did it take you to gain such vast knowledge?
/ Fitting size #5
JJ,
That's a common-as-dirt fitting that you shouln't have to jump through hoops to find. Baum, Surplus Center or any local hydraulics shop or reasonably well-stocked equipment dealership likely has in stock at a nominal cost.
/ Fitting size #6
In your private message, I thought you were looking for female thread on the NPTF side. If you actually want a male thread, then the photo JJ posted is of the fitting you want. 6401-08-08 on our web site. It is a pretty common fitting. You can order it here O-Ring Boss (ORB) x Male Pipe NPTF) Adapter or you can probably find it a local hydraulic repair shop.
/ Fitting size
Thanks Ken,
I'll wait until the cylinder arrives to order the adapter. That gives me time to see what else I need. I had never heard of a UNO fitting before.
/ Fitting size #8
Thanks Ken,
Neither had I. Until yesterday, UNO was just a card game to me. :)
Seems people make up their own names for things all of the time. I did some sleuthing on the Bareco web site, and determined that "UNO" was some kind of shorthand for UNF thread with an O-Ring. I already knew that SAE.ORB fittings all use UNF thread, so it was an easy leap to figure out what they were talking about.
/ Fitting size #9
G'day guys don't you lot start on having strange way of saying things sometimes it can take me hours to work out what you are talking about:laughing:. But seriously Bare co stuff is of a good quality and you are right they are an aus co been supplying aftermarket parts for years and i have not had an issue with their stuff
also there is a very good size chart on their website to help you work out hyd fittins
Jon
/ Fitting size
My cylinder arrived yesterday. I picked up a fitting @ TSC for a test fit. The fitting says 1/2 male o-ring to 1/2 JIC male. The threads are 3/4-16. It fits. I am assuming that the "male o-ring" side is an SAE 8 going by my surplus center catalog. The JIC also threads in but I know it does not have the correct seal type. If I am correct in calling it an SAE 8 all I have to do now is get my list of goodies ready and figure out my lift pole attachment for my trailer mover. Thanks for all the replies, Matt
/ Fitting size #12
Here is the chart I use: Fluid Port Size Charts > Discount Hydraulic Hose.com
