Fitting size
/ Fitting size #1
ffclassic
China, Texas
2010 kubota m7040 dtc
I purchased a BARE-co cylinder on Ebay and I'm not real sure on the size of the ports. I think it is an Australian company.
These are the specs:4"Bore x 18" Stroke
Shaft Diameter 2"
Closed Length 28 1/4"
Pin Diameter 1"
Ports 3/4" UN O-Ring
Working Pressure 3,000 lbs
Is this the same as an SAE 8 fitting?
I got the cylinder brand new for $97.00 including $40.00 for shipping, hopefully I can find the right fittings. I plan on using it to add a boom pole to my 3pt trailer mover.
Thanks, Matt
/ Fitting size
/ Fitting size #3
Perhaps this. Straight thread ORB to NPT.
/ Fitting size
JJ,
I found BARE-Co's website. They have an office in Sacramento but do not sell directly to customers. They have an adapter PN B3440 which isA 3/4 UNO toB 1/2 NP. I have to fill out a parts request and then they forward it to a dealer. Maybe one of the hydraulics guys on TBN handles BARE-Co? Here is a pic of the adapter.
PS, I always like reading your replies. How long did it take you to gain such vast knowledge?
/ Fitting size #5
JJ,
That's a common-as-dirt fitting that you shouln't have to jump through hoops to find. Baum, Surplus Center or any local hydraulics shop or reasonably well-stocked equipment dealership likely has in stock at a nominal cost.
/ Fitting size #6
In your private message, I thought you were looking for female thread on the NPTF side. If you actually want a male thread, then the photo JJ posted is of the fitting you want. 6401-08-08 on our web site. It is a pretty common fitting. You can order it here O-Ring Boss (ORB) x Male Pipe NPTF) Adapter or you can probably find it a local hydraulic repair shop.
/ Fitting size
Thanks Ken,
I'll wait until the cylinder arrives to order the adapter. That gives me time to see what else I need. I had never heard of a UNO fitting before.
/ Fitting size #8
Thanks Ken,
Neither had I. Until yesterday, UNO was just a card game to me. :)
Seems people make up their own names for things all of the time. I did some sleuthing on the Bareco web site, and determined that "UNO" was some kind of shorthand for UNF thread with an O-Ring. I already knew that SAE.ORB fittings all use UNF thread, so it was an easy leap to figure out what they were talking about.
/ Fitting size #9
G'day guys don't you lot start on having strange way of saying things sometimes it can take me hours to work out what you are talking about:laughing:. But seriously Bare co stuff is of a good quality and you are right they are an aus co been supplying aftermarket parts for years and i have not had an issue with their stuff
also there is a very good size chart on their website to help you work out hyd fittins
Jon
/ Fitting size
My cylinder arrived yesterday. I picked up a fitting @ TSC for a test fit. The fitting says 1/2 male o-ring to 1/2 JIC male. The threads are 3/4-16. It fits. I am assuming that the "male o-ring" side is an SAE 8 going by my surplus center catalog. The JIC also threads in but I know it does not have the correct seal type. If I am correct in calling it an SAE 8 all I have to do now is get my list of goodies ready and figure out my lift pole attachment for my trailer mover. Thanks for all the replies, Matt
/ Fitting size #12
Here is the chart I use: Fluid Port Size Charts > Discount Hydraulic Hose.com
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2019 CHEROKEE TRAVEL TRAILER (A63569)
2019 CHEROKEE...
Heavy Duty Plate Compactor (A64047)
Heavy Duty Plate...
2017 TAKEUCHI TB290 EXCAVATOR (A64279)
2017 TAKEUCHI...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
