Scafer for Boxblade
   / Scafer for Boxblade #1
bakerg
Super Star Member
Tilbury, Ontario, Canada
John Deere D110
Started building a boxblade in the fall and had put it away for the winter as I do not have a heated garage to work on it. After reading some forums on here, I got it out and have been using it to move snow. I still need to install scafers on it in the spring and I was just wondering what I should use. I do not want to spend alot of money on this and I am trying to use scraps I have around the farm. I have some scrap steel and was going to try to make my own scafers but was wondering if I could use tines off a triple K that I have lying around. Would they hold up when I do my laneway or would they just snap in half? Here are some pics of the boxblade, I will need to make some modifications to the 3 point hitch in the spring.
   / Scafer for Boxblade #2
I think you are meaning "scarifier". I am going to be building my own box blade this spring, and I am gong to make them out of 2-1/2 x 3/4 bar stock to mimic commercially available ones. not sure if I am going to try to put cutting teeth on, or just cover the "J" portion cutting tooth with hard face welding for abrasion resistance.
   / Scafer for Boxblade #3
...was wondering if I could use tines off a triple K...
Not sure what that is, you have photos of what you are thinking about using???
The tines look like what is on this culivator.
Yes that what I meant, I think:confused2:
   / Scafer for Boxblade #6
Those are designed to "give" I think they are called "S" tines and have spring to them. You could use it but it's very different from the very ridged box blade tines. If you are looking for aggressive deep digging, the S tines will not work that well. S tines break up dirt clogs very well.
Just want to use it to level out the driveway, I will not be using it on a regular bases. Drive way is based sand and gravel with 3/4 clear top.:D
   / Scafer for Boxblade #8
Should be good to go... :thumbsup: How many were you planning to use?
   / Scafer for Boxblade #9
I bought a used box blade a few years ago to do our driveway (800+') as well as neighbors plus family members & I think I have used the scarifiers grading twice. I will cut ALOT more than you think.
Mine is a Woods/Gill blade with the flip over scarifiers, which make it easier to engage the rippers than the standard type, & I still don't really use them very often.
I'd try yours as-is & see if you really need them.
Tried out blade in fall without the scarifiers and it worked ok but I would like to loosen up the high spot in driveway and thought the scarifiers would help.:D
   / Scafer for Boxblade #12
I found out that the high spots on my driveway were there for a reason, large rocks or stumps. (Dad built the road with an axe and a chainsaw. No tractors)
   / Scafer for Boxblade #13
Agrisupply has the best deal on scarifiers when I was shopping for them a while back. Scarifier
   / Scafer for Boxblade #14
I made my own out of leaf springs off a Mack truck, cut them to the desired length with holes in the top to place a pin through, cut them to a point on the bottom. They ain't much but they were free, they serve there purpose and they haven't broke YET.
   / Scafer for Boxblade #15
When I built my box blade I just used some scrap 1/4" diamond plate cut to the shape of the commercially available ones, they have held up well. I did add some angle iron to the end for a more aggressive action in virgin soil.
Well I made my own scarifiers out of 2X4 tubing, seems to work good.:thumbsup:
Got everything welded together, just have to paint. Took it out for a trial run and works better then expected.:thumbsup:
Heres the box blade all painted, green and yellow sure look good.:thumbsup:
Well I had some time so I thought I would do a little mod to the boxblade.:D Originally I had just nipped off the corners. :)
Uploaded with ImageShack.us
But what I found was, when I made an adjustment on the 3rd link, the side would dig into the ground. :eek: So I figured I would add a lead in to stop the sides from digging in. ;)
This works so much better now. :cool: I can adjust how much snow I leave on the driveway with out worrying about gouging the driveway and digging up stones. :D
   / Scafer for Boxblade #20
When I was at my LS dealer and rummaging around, he had several stacks of scarifier teeth and I had bent a few of mine so I asked how much. $10 each so I bought 3 for spares. I couldnt build one for that price and they all had the replaceable chisel teeth on them
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
flatbed trailer 24ft (A56857)
flatbed trailer...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
