Starting 855 in cold weather
/ Starting 855 in cold weather #1
bob arnold
john deere 855
I have a John Deere 855 that is housed in an unheated garage. I use it to move snow out of my driveway and that of my neighbors. Getting it to start on a cold day is a chore. I've looked at adding a block heater and may do that this summer.
There is apparently no glow plug type heater or any way to put starting fluid into the system, so the block heater seems to be the only alternative.
Does anyone have a better idea?
/ Starting 855 in cold weather #2
A block heater is an excellent idea and I strongly suggest you do add one.
As far as no glow plugs or other cold weather starting assist, I think you're wrong...if you have a manual, look it up. If not, I'm sure someone will post the procedure soon enough. In the interim, you might try turning the key counterclockwise and see if the glow plug light comes on (that's the procedure for my old 670 and 790) or turning it to the run (not start) position and pressing it in (procedure for the 4400, 4300, 4200 Deeres).
Do not use ether or other starting fluids!!! BAD BAD BAD!!!
/ Starting 855 in cold weather #3
Your 855 has a "air intake heater", part #15 in the diagram below. Might want to check it with a ohm meter and make sure it has continuity, it should read near zero ohms.
/ Starting 855 in cold weather #4
What's the book say about the procedure to use the heater, Kenny?
/ Starting 855 in cold weather #5
No book online for this model unfortunately...I checked. They only have the newer ones posted.
Thanks everyone. Although the manual doesn't tell me this, thanks to this forum I learned that if I turn the key counterclockwise and wait a few seconds, the air intake heater kicks in and that makes starting much easier.
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
FORD 5 BOTTOM SIMI MOUNT BOTTOM PLOW (A63291)
FORD 5 BOTTOM SIMI...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
