Elklakedoug
Member
- Joined
- Jan 18, 2011
- Messages
- 39
- Tractor
- John Deere 2320
Seems most that use tire chains put them on the front. I've seen a few of you with chains on the back. What's your experience and/or the conventional wisdom out there?
Seems most that use tire chains put them on the front. I've seen a few of you with chains on the back. What's your experience and/or the conventional wisdom out there?![]()
I'm cutting all the cross links shorter so they will go down only about 3" on each side. I don't have a set of those chain pliers to do this and it took me 5 hrs. to do one chain with a cold chisel and hammer to seperate the connecting links. Hope to get the other one done tomorrow.
I just came in from my shop. I've been working on a set of chains for the rear of my 4200 4WD. JD. There is not much clearance on the inside to the fender. I can reverse the wheels and only gain 3/4". I was given a set of chains, but they were quite wide for my tires. They wrapped around and down the sidewalls too far for clearance. I'm cutting all the cross links shorter so they will go down only about 3" on each side. I don't have a set of those chain pliers to do this and it took me 5 hrs. to do one chain with a cold chisel and hammer to seperate the connecting links. Hope to get the other one done tomorrow. I can't get up in the woods to get my fire wood and only have enough left for about 10 days. I need to go to auto pars or someplace tomorrow and get something that connects the chains and locks. What do you think about just using the cain links that have a threaded nut on one side and then a few bungys on the outside to keep them tight. I'm open for any help out there as to what i'm doing. I would have just bought the correct size chains for it, but money is really scarce right now.
Thanks all,
Clayton
Thanks for the tips on the chains.
"Beenthere", Did you reverse your wheels around, or were they ok for clearence. .............Thanks
Clayton
