Too Cold??
/ Too Cold?? #1
Airedale
Central NY
Ferguson TO 30 - TYM T433 Cab - Power King 1614
I have had no problems starting and running my current diesel tractor, a TYM or the Kubota I had previously in temps that get into the teens. I have always used seasonal road fuel from a station close to me and add the power service additive. My tractors are kept inside my unheated barn
As many already know in the Northern part of the country a good cold snap is coming in, they are predicting temps well below zero in my neck of the woods. I also expect a good shot of lake effect snow. So there looks like there is going to be some major snow removal to take place and at the same time there will be sub zero weather.
My question is does there come a point where the temps become so low that they interfere with these tractor's diesel engines where they can not be operated properly even if they get started and warmed up???
Al
/ Too Cold?? #2
Al
Al, I live in northern Michigan, and yes, this week's weather is brutal.
That said, we still cannot compare ourselves to the guys in Manitoba or Alaska and those fellas will tell you that they go right on working.
Good preventative maintenance, good 5w- something oil for easier starts, a block heater, sometimes a battery heater, proper warm up procedures and you are good to go.
Folks in northern Europe, the Ukraine, Korea, etc, all have similar challenges and diesel tractors are all working in sub zero weather.
I gotta go plow out the barn and some lanes today. Yea, it's cold.
/ Too Cold?? #3
Al
No. As long as the fuel is properly treated. You may need to idle the tractor at a little higher RPM to get it to warm up.
-17* here this morning with no issues.
/ Too Cold?? #4
There are so many posts about this subject. when you get it running let it come up to operating temperature. Restrict engine cooling with the oldest trick in the book a piece of carboard cut to fit the rad with a round hole in the middle.
Craig Clayton
/ Too Cold?? #5
Used to be a regular seen item even on cars.:D
/ Too Cold?? #6
As someone else said -- fuel must be properly treated -- I once had an entire fleet of diesel trucks shut down because summertime fuel was "jelling" in the tanks and lines. Otherwise, once started they will run:thumbsup:
/ Too Cold?? #7
I think the Power Service (white bottle) is rated down to -40* as long as you mix it accordingly.
/ Too Cold?? #8
we were hauling grain today at -33c with -41 wind chill and i actually have no conditioner in the tractor loading . I don't think i've ever had a tractor gell on me , plow trucks frequently do on snow removal though.
/ Too Cold?? #9
Keep a few new fuel filters on hand, at about 0 is when you may begin to have problems and the filter will generally be the first thing to clog with wax. To check for cloud point might be a good idea to store a small quantity of diesel in a clear container next to the tractor.
/ Too Cold?? #10
Do you have different diesel in the tractor's and the trucks? On road and farm?:confused:
/ Too Cold?? #11
5 below zero here, Massey won't start. Pulled the fuel filter to check.............sure enough, gelling fuel with Power Service added.:mad:
/ Too Cold?? #12
Wow, now you guys have me worried I've never added anything to my fuel cept lucas once in awhile, where getting that nasty cold coming as well.
I don't have to start tractor or truck in the morning's worst part of it unless there's snow.
My question is once a fuel system is clogged with gelling, will it thaw by itself? in other words if a filter is clogged with wax, can you just force heat it, to flow again? or would it have to be replaced.
Thinking if I get in a bind I could just aim my 110 K btu oil fired heater at it for awhile and not have to get my hands dirty?
JB.
/ Too Cold?? #13
JB.
That will work fine, just don't burn the paint.
I put an 'oil filled electric heater' beside my tractor, covered the tractor with a blanket, and 1 hour later it fired right up. I'm just about to go out and move some snow now.
/ Too Cold?? #14
Yes tractors are on dyed farm diesel and trucks are on highway fuel !
/ Too Cold?? #15
Do some research on building the Alaskan Pipeline sometime if you want information on how cold can affect equipment.
We're not that cold here, fortunately.
As far as the cold we're currently experiencing in the Mid-Atantic to North East, I'd say it's a lot tougher on the operator then the equipment.
/ Too Cold?? #16
An acquaintance of mine worked on that project and he really had some stories. He made enough money to retire in his 40's.
/ Too Cold?? #17
Al
The two major problems with cold diesel operation are turning the engine over and getting fuel to the injection pump. The physics of the situation is you need more power from the battery with a cold diesel at the same time that the battery output is down due to temperture. Enter the block heater. It warms the coolant and subsequently the cylinder liners and that reduce the starting requirements substantially.
The issues with fuel are water contamination at temperatures below freezing and fuel gelling at temperatures lower than ~-30F ish. Water contanimantion can freeze at the tank outlet, in the water separator and on the fuel filters shuting off the fuel.
To deal with this, keep the tank full, change your fuel filters before late fall or before any predicted cold snap, add something like PS White to the fuel to help disperse the water so the filter can take it out, drain the water separator and the ful filter before and after every use, and keep a spare filter handy. The fuel additive will keep the water in suspension so the filter can take it out and f some time it'll freeze on the filter. Then you replace the filter. That's a lot easier than dealing with a frozen tank outlet. You can still freeze a filter if your fuel is really contaminated with water in real cold temperatures so you really have to focus on having "dry" fuel.
Our friends in the great white north have to deal with fuel gelling as do the people in the really cold spots of the US. Fuel gelling is the waxes in the fuel (that provide energy in the combustion chamber) begin to percipitate out at temperatures around -30F plus or minus. .They can clog the tank outlet screens and fuel filters with a wax type coating. I mix 1 part of #1 diesel with 2 parts of #2 diesel to reduce this possibility and use PS White per the label to help disperse waterand to lower the pour point.
Once you get the tractor started and can keep the fuel flowing, the problem becomes one of getting the hydraulics warmed up which I do my alloewing the hydraulic pump shear the fluid down and then i drive it around so the rear axle can help.
In really cold weather, you might have to use lower vis lube oil and hydraulic fluid and your coolant has to be mixed for lower temperatures. There's nothing per se about the diesel that says it won't operate at really cold temps you just have to deal with the problems mentioned above.
/ Too Cold?? #18
Are you sure your filter isn't iced? -5F is not a temperature where you usually get gelling of fuel.
/ Too Cold?? #19
Was definitely gelling. I'm using ULSD which gells at a higher temperature.
I pulled the filter, and looked into the glass bowl. Fuel was very cloudy, with solidification making long 'tails' thru the fuel. then I pulled the filter, seperated the folds carefully, and I could clearly see the 'sludge' sticking in the folds.
Heat took care of the initial problem, and I doubled the dose of Power Service(which I found out later that you are supposed to do in winter), tractor ran great for 2 hours.
At what temperature does diesel freeze? | Answerbag
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
2019 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59911)
2019 HINO 268 4X2...
SET OF UNVERFERTH LIFT ASSIST WHEELS & REACH ARMS (A63291)
SET OF UNVERFERTH...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
