Oil & Fuel Getting pink spots on snow when using 3032E
/ Getting pink spots on snow when using 3032E #21
I have a 4110 and I get red spots when blowing snow. I know exactly where it is coming from--hydro tranny--but I haven't got around to fixing it. I will when the weather gets warmer. In the meantime I keep a close eye on the fluid level. But, to the point, my hydro fluid is red.
Never changed the fluid?
I ran the tractor for about a half hour today and didn't notice any spotting. It is down to a half tank of fuel now also so not sure if that is influencing it. But......now the bucket on the front end loader rolls up slowly at a certain spot.
Think it's time to get rid of this tractor.....with a whopping 7 hours on it. Guess there is no lemon law for tractors.:(
/ Getting pink spots on snow when using 3032E #23
Don't feel bad my 2320 has less than 250 hours and the water pump leaks when it is cold. Guess it's just one of those things. Still like the tractor though.
/ Getting pink spots on snow when using 3032E #24
The hydro oil that came with my 790 when bought new was red.
The oil I bought from them to do my first change was clear.
Bingo, so was mine.
/ Getting pink spots on snow when using 3032E #25
As I posted earlier, I have a new holland t1110 boomer (1030 is new model number), and see a few red spots in snow after plowing. I have no red fluids in the tractor. I haven't gotten around to telling my dealer. 109 hrs on it.
/ Getting pink spots on snow when using 3032E #26
Yes, I have changed the fluid. The new was rather clear (sort of a light amber) but it still shows red in the sight glass and drips red spots, Funny thing is, it only drips when the snow blower is working extra hard--drift or very deep wet snow. Never drips when parked or under "normal use".
/ Getting pink spots on snow when using 3032E #27
Maybe the lemon is on the seat? :D
/ Getting pink spots on snow when using 3032E #28
I see pink spots in the snow also with my 2010 JD 4320. Like others, I've checked for leaks and found none. I use off road diesel fuel which is pink and I'm thinking it could be unburnt fuel/dye from the exhaust. Anyway I will be looking closer to prove/disprove this theory as soon as we get some snow.
/ Getting pink spots on snow when using 3032E #29
Same thing happened to me a few yrs ago with my 3203, asked here and nobody could pinpoint it. It did it for 3 yrs, never found the source. Just dealt with it and watched for low fluids, which never happened.
Now this yr with my 3720 I get the same pink spots. Sometimes they are on the right side, sometimes the left, but always seem to be on the inside edge of the tire track. No pink/red fluids in this tractor either. Still seems baffling to me:confused::confused: But just deal with it I guess.........
/ Getting pink spots on snow when using 3032E #30
Can you swirl a paper towel around the inside edge of the exhaust pipe, & see if it comes out pink/ red?
/ Getting pink spots on snow when using 3032E #31
I posted a question about how clear my hydro fluid is (http://www.tractorbynet.com/forums/kubota-owning-operating/194123-hydro-fluid-extremely-clear.html)
... and kennyd responded that Deere sells a red dye for hydro fluid to make it more visible thru sight glasses & on dipsticks.
1*Maybe it is hydro fluid?
1*Red dye in the hydro fluid makes sense to me.
I just bought a brand new John Deere 3032E diesel and noticed there are pink spots in various locations on the snow where I have run the tractor. I just got it back from the shop and they said they couldn't find a diesel leak.
2*I Believe the hydrolic fluid is a different color so ruled that out.
2*Why not look at the fluid and see what color it is.
Kebo, I am unaware of any JD fluids with a red color.
3*Perhaps you are mistaken.
4*Rick, I assume you are using off road diesel. Make sure your fuel bowl is tight. I did a quick search for tech bulletins on that tractor. Nothing reported at this time.
3*I don't think he is cause JD sells a red dye for hyd tranny fluid.
4*Or it could be red dyed hydro fluid rather than diesel .
/ Getting pink spots on snow when using 3032E #32
Rim Guard in the tires? I have Rim Guard in all four tires and wondered if it could have been splattered on the tires when filling (it has a reddish color). Just a thought.
/ Getting pink spots on snow when using 3032E #33
Apparently, it's a hydraulic leak.
/ Getting pink spots on snow when using 3032E #34
CC in all 4 tires on both tractors.... but after 3 yrs and 300+ hrs on the 3203 I would have had a tire or 4 go low if the tires were leaking fluid. Same thing on this 3720 @ 74 hrs now...... I will try to remember a camera tommorow as it is snowing like mad right now and get pics.
I checked the exhaust thinking maybe it was coming from there...one of the first things I did....it was bone dry. I also noticed pink snow stuck to my INSIDE real wheels. This would make me believe that the fuel is running down the fuel tank and dripping off. It is not being thrown or it would show on other parts of the tractor. I say it is the fuel gauge that is leaking. It all looks flimsy with the plastic tank. Mine isn't glued to the tank or anything and has a rubber gasket between gauge and tank. Since I am down to half a tank now it isn't doing it....or as much. Hope we get the snow tonight. Run it with half tank....then fill it and run it to see.
/ Getting pink spots on snow when using 3032E #36
I had trouble trying to find the leak on my 4110. I finally determined it was coming from the tranny, but I couldn't see where. I cleaned off the tranny (used brake cleaner) and dried everything. Started the blower and pushed it into a big drift a couple of times till I saw spots. Found fluid at the bottom of a plate that is bolted on the side of the tranny. It is one of those "no gasket" fits that apparently seals fine until the blower is at full RPM's and under heavy load.
/ Getting pink spots on snow when using 3032E #37
Pics.... no smell, feel of oil, taste:eek::eek:lol No clue after 4 yrs as to what it is... maybe Deere's way of marking their territory:eek::eek:
No snow here in NJ, just a rain event. I checked my rear fluid for the 3rd time in 2 weeks and noticed instead of a light brown it is green now so wondering if the dealership dyed it green looking for a leak. Next snow it will be leaking either green or red. Anyone want to place their bets??:laughing:
/ Getting pink spots on snow when using 3032E #39
Is it always in the tire tracks?
/ Getting pink spots on snow when using 3032E #40
Does the trans have any vent that vapor could be coming from when it's worked real hard?
Any grease fittings weeping? That's if red grease was used.
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61573)
2010 Ari Hetra...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A61572)
2018 Caterpillar...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
