Makita 6401
/ Makita 6401 #21
I'd gues after get a 6401 the MS290 will just collect dust, the 56cc 290 doesn't even cut as fast as a good 50cc saw. Steve
/ Makita 6401
I agree that he doesnt "need" the kit. I only suggested it IF something were to go wrong with the top end in the near future.
As to bar length, I perfer a 24" bar. That it what I have on most of my saws. And it is NOT because we cut big wood all the time. The reason I like the 24" is because I dont have to bend over. For me, a 20" bar is harder on my back and tires me out quicker because of this.
You got that right. I love a 24" bar for nosing into the work.
4" makes a big difference :D
/ Makita 6401 #23
With the big bore kit your saw would go from normal to screaming fast.
I have a Dolmar 7900, which is basically the 6401 with a bigger p&c. It really rips, and it is very easy ro handle.
/ Makita 6401 #25
You deserve to be tortured if you let that saw slip away:D
/ Makita 6401 #26
If you've seen it and know it's a good saw then there's always UPS. :laughing: I'm I not helping?
/ Makita 6401 #29
Isn't a longer bar more likely to "kick-back" because more bar gives you more chances to get the tip where it shouldn't be?
My saw has a 15" bar and has cut some pretty big trees. But I do have to bend over.
/ Makita 6401 #30
:confused::confused::confused::confused::confused:
The 120SI is one of the BEST saws dolmar ever made.
I did not mean the 120 SI in general. It was only this one we had. Dolmar was not common here in 1990 and noone was able to say, why we received a Dolmar, cause originally the truck came wit 2 Stihl 044.
I traded in a 120 SI a few years later and it was much better.
The PS 34 is not bad and the only thing I don not like is the design, which is not really important. But it works fine and is worth every Euro.
/ Makita 6401 #31
I guess you could look at it that way. But just be cautious and know your equipment.
I will say that In my case, I think a 15" bar would increase my chance of kickback. Because we often cut wood larger than 15", and when you cannot cut all the way through, theres an incresed risk with the tip burried in the wood as opposed to being clearly visible on the other side
/ Makita 6401
Here's the saw. Looks like it might be an older version. Does not say "makita" on side of handle like newer models.
/ Makita 6401 #33
So ya got it:thumbsup:
If she runs good, I dont think you will be disappointed.
/ Makita 6401 #35
No, no. haven't bought it. Those are the just the sellers pictures. :laughing:
Ah, ok.
Well it looks pretty good.
It's hard to tell but in the second photo, the greay plastic top cover looks like it may have had a sticker on it at one time??? I dont know, could just be a deception.
I would ask the seller if he would be willing to let you pop the muffler off to look at the piston and cylinder. If there is no or minimal score marks, it is a great deal. But if the piston is fried???????
Not saying that is the case with this saw, but HD rents the 6401's. They sell them off quite frequently. And a lot of them have scored pistons due to the renters using either straight gas or the improper mix. Just cover the basics. I dont mean to try to scare you away, because the 6401 is one heck of a good saw, and $275 is a really good price.
/ Makita 6401 #37
From what I can see in the pics, the saw looks to be in nice shape. I was not able to enlarge the pics for a better look. If you are looking at having it shipped rather than going to pick it up, you are kind of at the mercy of the seller. I have worked with people most of my life and can usually read them pretty well.
So either take the time to drive and check it out for yourself, or roll the dice and hope the seller is honest and have it shipped. Assuming the saw is solid, it would be a good buy. Even if it needs a P/C, it would not be the end of the world. You would still end up with a good saw at a fair price.
/ Makita 6401
That's exactly what I'm thinkin.
Might be an excuse to hop it up. :thumbsup:
/ Makita 6401 #39
Now your talking.
And dont forget, when doing a "compression" test by pulling on the rope to get a feel, make sure the compression release button isn't pushed in:thumbsup:
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2019 Kubota SVL95-2S (A64126)
2019 Kubota...
iDrive TDS-2010H...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
