Winch Modifications
/ Winch Modifications #71
Could you not connect a short 3/4 hose across the motor with a needle valve in the middle to shut off the flow when using the power mode. Just open the valve to max to free wheel.
How about a wireless remote control valve to power unwind and wind. No free wheeling necessary.
The 422 does not have electric solenoids on the valves. Looks like this would be more modification that I want to do, but perhaps as a last resort.
The needle valve sounds like a good idea.
J_J will the motor be easier to move if I break it in? It has maybe 30 minutes of operation on it now at most.
/ Winch Modifications #73
/ Winch Modifications #74
Yes, the more you use a hyd motor, over time some the fluid will bypass internally.
Thanks JJ. Since I am bypassing it externally, then internal bypass will not be of much help (I think, correct me if I am wrong). I am thinking it's like a new engine, very hard to turn over, but once it's broken in it spins much more freely. I think you have partially answered the question, just not absolutely sure. Any idea for break in hours (1/2, 10, 1000). I probably just need to pull the cable off and let it run for an hour and see if I notice a difference. Obviously I don't want to put a 1000 hours on the machine to break in the winch.
I pulled on it today with the short hose bypass. It was still a lot of work, but maybe doable.
/ Winch Modifications #76
I would be tempted to try that first valve i mentioned. That could be a permanent setup on the winch. You would only need a Tee on the supply side of the winch and a short hose between that Tee and the valve. The valve connected to the return of the winch. Then just your normal hoses from the supply Tee and the valve to the PT. Depending upon the sizes of the hoses, it could be less than $100.
Ken
J_J, I got to thinking more about your wireless remote above. Even having a manual valve for wind and unwind at the winch would be a big help. The electric would be even better. I will take a serious look at this.
/ Winch Modifications #78
There are some inexpensive wireless contactors used for ATV winches that could easily power a solenoid valve.
Ken
Those wireless remotes are very reasonable.
On the valve, if the center is completely open, then the winch will freewheel when centered. Would it be better to have the winch locked and the pressure line returned to tank. I believe this is called a tandem center. Also the hoses in this system are 1/4 inch. I think the valve when be cheaper in it was 1/4 inch. Thanks again for your efforts. It may be time for me to call surplus center.
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
1004 (A61166)
1004 (A61166)
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
AGT Industrial ExRC54 (A60463)
AGT Industrial...
2019 FORD F-250XL EXTENDED CAB UTILITY TRUCK (A59823)
2019 FORD F-250XL...
