Erratic Hydraulics
/ Erratic Hydraulics #41
Thats got to be it. Either oil can't get into the pump fast enough, or there is a restrictor fitting. Like JJ said, look for a standard fitting with a 1/8" or smaller passage. A restrictor plate could be installed between what looks like 2 fittings. Ford use to put one way restrictor plates between 2 fittings on the hoses. The idea was a fast raise, slow drop, or fast curl, slow dump. A lot of times, these plates were installed backwards, that would cause a slow lift, fast drop, etc.
Restrictor fittings would slow the functions in both directions. A little piece of debris in the fitting would make them restrict even more.
Also, never rule out a QC as a restrictor. If they are mismatched, say a Parker w/a ball check plugged into an Aeroquip w/a poppet check, the QC's wont open all the way. And, damaged or worn QC's wont open all the way, either.
I have checked and cleaned the transmission filter screen. It is clean and no holes or obstructions in the screen. The transmission has been flushed out with 3 oil changes until it is running clean with no milky look or foaming.
There are no QD in the system. I built the loader and installed all of the hydraulics. There are no leaks in the lines or anywhere and it runs quiet and smooth. The 3pt still works as it always has and doesn't have any problems lifting either. I have also noticed the 3pt doesn't work any faster with rpm either. But then, I don't know the ins and outs of how the internal workings are in it so it may not matter with rpm.
/ Erratic Hydraulics #42
Your problem sounds like it is caused by a mis-plumbed priority valve in your system....sending priority flow to your 3pt and FEL, and exhaust flow to power steering?? LOL
/ Erratic Hydraulics #43
That would be a new one...alway possible.
/ Erratic Hydraulics #44
That could be it except I don't have power steering or a priority valve.:laughing: Maybe I just have situation that I am stuck with.
Does anyone know if the bigger Yanmars (2210 and up) have a larger volume pump that I could interchange with mine. That is if I could locate one;)
/ Erratic Hydraulics #45
Maybe at max flow through your valve, so revving up causes valve to restrict extra flow? You would be dumping extra through relief.
/ Erratic Hydraulics #46
well, it is a 10gpm valve getting 4gpm flow, so it shouldn't resist flow that much....I think the PRV might be stuck open a little....debris?? or CV still not allowed to 100% fully close "center" to tank....
/ Erratic Hydraulics #47
Not sure how I could tell that. The gauge goes back to zero when the CV returns back to the center when using the loader. If the PRV was not fully closed would the gauge show any pressure or would I hear some noise from it?
I do see when the 3pt creeps down that the gauge will start showing pressure and I hear something start relieving but I don't know if it is the 3pt or the PRV in the CV making the noise. lf I back off the 3pt handle a little then it goes back to zero and I don't hear the noise.
/ Erratic Hydraulics #48
This is where a flow meter would tell you exactly what is going on. A pressure gauge only gets you so far, and you have been to that point for a while now.
/ Erratic Hydraulics #49
So, would the flow meter go in the tank port return line? Where would it give me the answer I'm looking for?
/ Erratic Hydraulics #50
Ideally it would go between the pump and main relief valve. From a practical standpoint it would probably be easier to install it before the inlet to the loader control valve. No matter where it is installed, you just need to consider which components are isolated by the test and which are not.
/ Erratic Hydraulics #51
If I put it in the main feed line it's going to show flow all the time as the system is an open center so oil flows whether I'm using the loader or not. I'm trying to find out why the loader and bucket does not increase speed when I double the rpm on the pump.
It has been suggested that I might have leakage somewhere and it's possibly bleeding off the excess oil flow. I would like to put it somewhere that I can see if oil is flowing where it shouldn't be or if there is a restriction somewhere limiting the oil flow.
I had a concern about the tank port return line back to the transmission possibly restricting oil flow but I am not sure how I could determine this or if this would actually cause my problem. I don't think it is since the bucket will dump very quickly and the loader will drop quickly if I let it. It just always seems to stay the same speed going up no matter what rpm the engine is at.
/ Erratic Hydraulics #52
Putting the flow meter here will verify all is well with the pump.
An internal leakage would be at a set amount, therefore, increasing pump output would still increase the speed.
Return line restriction would cause the pump to be under pressure when the control valves were in neutral. The pressure would increase as pump flow increased.
I would get a stopwatch and time the functions at idle, then at full throttle. I actually wear a chronograph for this very reason.
/ Erratic Hydraulics #53
Have you checked for restricted orifice on output ports as I suggested.
What happens when you use the 3pt and the FEL at the same time. You are pressurizing the total hyd circuit when you do this. If you have a heavy load on the 3pt, and lift, what happens?
/ Erratic Hydraulics #54
The loader valve has a PB port that goes back to the 3pt and the return line is separate from that line. The return line only flows oil when the loader valve is operated. Otherwise it has no oil flowing in it. I had to make an adapter to use my oil fill hole for the return line.
/ Erratic Hydraulics #55
JJ, I put all of the lines, valve and cylinders on new. None had any restrictor's installed and all cylinders are SAE6 ports. Valve work ports are SAE8 and in/out ports are SAE10. The loader moves reasonably well for a 4gpm pump but it doesn't increase speed between 1000rpm and 2000rpm. That's the part that has me confused. I would think it should speed up if even a little.
I can use the 3pt and loader only if I barely open the loader valve and then both move slow. Either one by itself will move quicker. You had told me a while back that my pump couldn't support both.
I can pick up the 5' bush hog and use the loader together but they will both go up very slowly. By themselves, neither one has a problem lifting a load. The 3pt also does not seem to go up any faster if I increase rpm but then maybe its not supposed to??
/ Erratic Hydraulics #56
If you install a flow control gage in line, then you will see how many GPM's are flowing at any rpm.
The reason I mentioned the restricted fittings, was that one of the members purchased a fitting for the hyd, and one of the fittings was restricted. It was not what he wanted.
/ Erratic Hydraulics #57
Did I read this right???
IF there is more than one return line, I think we have isolated your problem.
That return line to tank MUST ALWAYS flow oil in your system when valves are in neutral. If this return is the ONLY one, it must flow return oil ALL the time, even when operating. That is part of the "deal"with power beyond. If not, you valves are not plumbed in a true PB series.
I think you need to get a complete hydraulic schematic over YOUR original tractor system. Then we can see how your plumbing fits into that.
Comment about flow meters. If you try to use a flow meter with a restriction valve built in, consult with a pro, to avoid serious accidents. If it has no restriction valve, or if restriction is safely disabled, it is safe to use, because it will not build pressure.
See Bill's video...
/ Erratic Hydraulics #58
If the valve is using PB port for normal flow, then he would only have fluid in the return port when using the cyl.
A gear pump will pump continuously, and the fluid has to flow through something.
Picture of the valve and the hoses marked as to where they are connected would be useful.
/ Erratic Hydraulics #59
Here are the photos of the valve plumbing.
/ Erratic Hydraulics #60
Gary,
Just trying to catchup on this thread....Read it a couple of times and confused.......What is the original problem?..
Is it the dump cyls overrunning the pump gpm's?....:confused:
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
(4) Drive Tires off Kinze 3000 Planter (A65640)
(4) Drive Tires...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
