lockset freezing
/ lockset freezing #1
MESSMAKER
Bluegrass,KY
DK4710SE
My tractor lives outside. I am having trouble with the lock set freezing. It keeps the key out so I can't start it till I apply heat. I need to cover it with something that keeps out the water. What do you guys use? The tractor is a Bobcat ct225.
/ lockset freezing #2
have had that problem here in Pa. every winter.Several ways we have done, Heat your key,apply a wax or grease to key slot [will trap dirt in key slot if not wiped off be fore key is stuck in]'make a rubber cover out of old inner tube,buy and wire up a new switch with weather proff cover[some heavy equipment comes with these got one at a john deere dozer dealer for on of our farm tractor once.If your not to worried about someone stealiing it you could install a toggle type switch 3 position with a rubber boot.lastly take the key tumbler out of your switch and use a screwdriver to start and operate the switch.
/ lockset freezing #3
Spray some WD 40 into it after it's thawed to drive the moisture out
/ lockset freezing #5
Do you have Lowes or HD nearby? If so, I would peruse the fastener section looking in the slide out drawers with the odd ball items. I remember seeing a few screw/bolt covers that might work. If not, how about a waterproof cover for a cigarette lighter plug, hydraulic coupler cover/plug, etc.
HTH
/ lockset freezing
I will try the wd-40 for now. I think a waterproof cover is the answer, but I will have to find one or create one.
/ lockset freezing #8
A waterproof cover would work best.
If the keyset round base sticks out from the surface (rather than being inset), you could pop a condom over it.
BOB
/ lockset freezing #9
silicone spray will help shed the water too.
soundguy
/ lockset freezing #10
I have seen people use a tennis ball with one side split like a banana, then push it over the door knob.
I guess it works for a waterproof cover in a pinch.
In the mean time, if you heat it gently with a torch for a few minutes, you will drive out all the water.
I always give my locks a liberal dose of spray graphite in the fall.
IMO graphite is better because, it can't freeze, and won't evaporate like WD40, and it won't contaminate painted surfaces like silicone does.
/ lockset freezing #11
i have some lock lube in a lil pointy tube.... it's graphite in a silicone base... go figure..
soundguy
/ lockset freezing #13
Key switch protective cover - ACE ELECTRONICS Houston, Texas
or
Weatherproof Key Switch Cover
or even
if you have to
but I have used a magnet and a plastic bag
just put the magnet in the bag and stick it above the switch with the bag hanging over the switch it should keep 90 of the rain out.
tom
/ lockset freezing #14
What's your point?
i was just surprised they mixed them that's all. I've seen plenty of dry or greaseless graphite lubes ..... a bit touchy are we?
soundguy
/ lockset freezing #15
soundguy
No not at all, I was trying to understand an incoherent post.
/ lockset freezing #16
wow... i thought there was plenty of context.
OOOOOkay.. I see an early christmas present to myself coming on.
(click) (Click) (click)
Ahhh.... better than alka seltzer.. :)
soundguy
/ lockset freezing #17
I guess you won't discuss it, because you need to be right.
Clearly your still mad from the last time. Anyone who reads your posts can see that.
So, I'll let it go.
And, I will let you get the last word in. I can see that is important to you.
Have a nice Christmas.
2022 EZ-GO ELITE...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2024 14ft Pairboat Flat Bottom Mud Boat w/ Mudd Buddy HDR 5000EFI 40HP Mud Motor (A61574)
2024 14ft Pairboat...
SCAN TO RECEIVE TEXT UPDATES (A64276)
SCAN TO RECEIVE...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
