Loftness Timber Ax question
/ Loftness Timber Ax question #1
jlich3
Greetings, I'm a new here and was hoping someone could help me out with a question. I have found an asv rc100 with a loftness timber ax for sale that I plan on buying. Everything checks out and seems to run smoothly, but I could not tell if the high flow hydraulics were working properly. I lifted the timber ax about a foot off the ground and turned on the high flow hydraulics and revved the motor to nearly full throttle. The hydraulic pressure gauge on the timber ax had a reading of about 500 psi, while the gauge goes up to 5000. It was not under any load in terms of cutting and the blades spun freely with good balance. Does the psi increase under load or is there not enough flow? Admittedly, I could not read the hydraulic fluid level on the side of the machine. It was either full or empty as I could not see a line or bubble. Any help would be greatly appreciated. Thank you in advance.
/ Loftness Timber Ax question #2
I'm not familiar with that specific machine, but if you turn the attachment on low flow and let it spin, then activate the high flow you should notice a change. It may be a little more noticable at lower engine RPM's.
/ Loftness Timber Ax question #3
hope you like sharpening blades. and the angle has to be about perfect for it to mulch correctly. i have used the loftness timber axe head, i hate sharpening the blades
/ Loftness Timber Ax question #4
I have cleared about 10ac using the timber ax on a CAT 289. You will need to keep a grinder on the jobsite. Thats a good head for a home owner but not a great choice for somone doing it for a living. We switched over to the Loftness G2 and were much happier.
The gauage your looking at should climb up in pressure when you put a load on the head. You can also have a mechanic shop test the flow of the tractor fairly easily.
/ Loftness Timber Ax question #5
when you first start the machine at about quarter throttle you should see a quick jump in pressure then a rapid decrease to the level you are talking about..I have one on a RC100 that we used to use back when we were clearing and its a decent head for anything 4 inches and under..get much bigger than that and you are left wanting..
If you are not seeing a spike in pressure make sure you are spinning the head the right way...the Hi Flow on a RC100 is reversable so make sure that the rotor is spinning backwards not forwards (the Timber Ax is meant to spin backwards) this would account for not having a pressure reading....and you dont ever want the gauge to get to 5000psi ;)
/ Loftness Timber Ax question #6
With a hyd motor spinning,and with low volume/GPM's, you should see low pressure and be able to hear the sound of low speed hyd motor. As you increase the flow, the hyd motor will spin a higher rpm, and sound louder. Still, the pressure might be low, Now as you bite into some tough wood/brush, you should see the pressure increase, and the rpm fall off, sometimes even to stall the motor if you don't back off. The mulching head develops a certain HP to do the work, and when the hyd motor is putting up a lot or resistance, as in working, it can not develop the HP, and it will pull the engine rpm down. You should see the highest pressure at just about the stall speed.
/ Loftness Timber Ax question #9
I got one too sitting in the weeds.
I wonder if a Loftness Carbide Cutter drum would fit in the frame replacing the Timber Ax drum. That would give me reverse rotation mulching action with the motor being on the left side.
Anybody tried swapping rotors?
/ Loftness Timber Ax question #11
i'm in the market for a working good conditon set up
/ Loftness Timber Ax question #12
terrra ferma scott u stillhave the equipment for sale?
/ Loftness Timber Ax question #14
I would trade my Timber Ax for a high flow snow blower if anyone is interested. It snows occasionally here in Buffalo.
/ Loftness Timber Ax question #15
we have a Timber Ax laying around from when we used to do clearing work...we had it on Equipment Trader for awhile...call the guy I worked for doing clearing his name is John and his number is 804-761-1711..it was for sale for $12k at one point
/ Loftness Timber Ax question #16
i have a 2007 asv rc100 with forestry pkg with 600 hrs. with a loftness timberaxe,bradco grapple,forks,willsell complete setup for 49,995.00 0r if you are looking for just the loftness timberaxe i will sell it with extra rotor and teeth for 8500.00. call me at 770 313 2544
/ Loftness Timber Ax question #17
thanks, if i may why are you selling, can you forward photos. do you have a service/mainanace records. where is the unit located... what about a trailer?
/ Loftness Timber Ax question #18
The loftness drum are swappable if you have the same sizes. The G1 carbide cutter is 63". So if you have a 63" Timberaxe then is will swap. I have a G1 carbide drum that I am willing to sell.
/ Loftness Timber Ax question #19
I am selling because I just do not have any work for it,I can send some pics,just send me your email to muellervicki@bellsouth.net,I do have atrailer that I could sell with it,I am listing it on equipment trader and you should see pics by 2-7 12 or call me at 7703132544 the asv rc100 has only 652 hrs and the loftiness Timberaxe has under 100 hrs
2012 FORD F-450 FLAT BED SUPER DUTY (INOPERABLE) (A60736)
2012 FORD F-450...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
200 Gallon Tank (A57148)
200 Gallon Tank...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
