Installing quick connects
/ Installing quick connects #1
pdrrock
kubota b26
I have a L2800 with a LA 463 loader. I would like to install some quick connects for the dump to also use for the angle on a plow. I'd rather avoid the cost of a third valve. Can someone tell me how to do this or lead me in the right direction. Thanks
/ Installing quick connects #3
Let me ask this another way. Do you want to install QD's on the curl cylinders, and QD's on the plow cylinders, and just plug in to the curl circuit QD's as needed. You have to be careful about QD's, should you forget to have something connected, the FEL valve will go into instant relief.
Yes. As far as I know, Curtis does this with their plow with a QD setup and a chain so the dump stays flat. They have no info on the website on how this is done. Hydraulics is new to me so I'm not sure what I need to set it up myself. I can buy a third valve but I can't see spending $600 or more just to make the plow angle. What's the advantage? Not sure what instant relief is.
/ Installing quick connects #5
You don't need to spend that much to angle the plow. A diverter valve, and a DA cyl will do that. The fluid from your curl function goes to the diverter valve, and the curl cyl hoses go in one side, and the plow hoses go in the other side. One switch position, the curl works normally. In the other switch position, the lever for the curl controls the plow angle.
The system will go into relief when the pressure builds up to the relief setting. The setting on the relief is there to protect your components from over pressure.
https://www.surpluscenter.com/Instruct/I9-5117-A.pdf
I Think I'm understanding you. Thank you very much
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
