Installing quick connects
/ Installing quick connects #1
pdrrock
kubota b26
I have a L2800 with a LA 463 loader. I would like to install some quick connects for the dump to also use for the angle on a plow. I'd rather avoid the cost of a third valve. Can someone tell me how to do this or lead me in the right direction. Thanks
/ Installing quick connects #3
Let me ask this another way. Do you want to install QD's on the curl cylinders, and QD's on the plow cylinders, and just plug in to the curl circuit QD's as needed. You have to be careful about QD's, should you forget to have something connected, the FEL valve will go into instant relief.
Yes. As far as I know, Curtis does this with their plow with a QD setup and a chain so the dump stays flat. They have no info on the website on how this is done. Hydraulics is new to me so I'm not sure what I need to set it up myself. I can buy a third valve but I can't see spending $600 or more just to make the plow angle. What's the advantage? Not sure what instant relief is.
/ Installing quick connects #5
You don't need to spend that much to angle the plow. A diverter valve, and a DA cyl will do that. The fluid from your curl function goes to the diverter valve, and the curl cyl hoses go in one side, and the plow hoses go in the other side. One switch position, the curl works normally. In the other switch position, the lever for the curl controls the plow angle.
The system will go into relief when the pressure builds up to the relief setting. The setting on the relief is there to protect your components from over pressure.
https://www.surpluscenter.com/Instruct/I9-5117-A.pdf
I Think I'm understanding you. Thank you very much
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
Bigfoot with Flag (A64557)
Bigfoot with Flag...
2004 JOHN DEERE 750C LT SERIES 11 CRAWLER DOZER (A65053)
2004 JOHN DEERE...
