Backhoe & MMM compatibility issue (2X20)?
/ Backhoe & MMM compatibility issue (2X20)?
OK I just made a simple little comment and look what happened......
I had no idea there was so much interest. Sorry, working too much all weekend, didn't see the questions.
Attached a quick picture of a section of the underframe.
I don't know if this answers the question. I certainly have to take my mower deck off to put the BH on, but just the deck.
I figured there would be interest! Thanks for pics. Question? I see the notches in the frame/bracket, But I'm not sure I see the additional steel.
Anyway, great information!
OneMarineE5 ,my brother has the 2720 has over a 100 hrs and 7 or 8 mo old, he says it is one fine machine .
That's good to hear! Hey etcallhome, I'm originally from Brushy Run in Pendleton County. Do you know where that is?
/ Backhoe & MMM compatibility issue (2X20)? #23
I have always understood that the back hoe was built to mount on any tractor with a three point hitch. My 2720 was bought based on what I saw on the JD site as far as the ease of switching from one tool to another. If I remember correctly, the demo did not say anything about removing any parts from the tractor, and claimed you can pretty much do it all from the seat with the only exception of getting off to connect the hydraulic hoses. Am I also wrong on this?? My dealer knew I planned to get the back hoe and never mentioned any of this to me!! I have the independent lift with the diverter valve, and he sold me the power beyond kit for the back hoe application. I really hope I wasn't mislead
Wooden
Wooden
All I know (as I have confirmed this thru dealer) is that, if you have your MMM on and unhook and then drive off of it....you are not ready to mount BH. After driving off MMM you have to crawl under tractor and remove several bolts to remove the MMM bracket/frame. Once the BH is on, MMM is not going on until you remove it and then replace your MMMs bracket/frame:mad:
My dealer did not make me aware of this either, however I am not certain he knew. Once I got suspicious (I was not yet certain) and brought to his attention, he said he'd look into it and get back to me....he confirmed my fears. He was very pleasant about my no longer wanting MMM to purchase X500. He still gave me a deal on X500.
Do you already have the MMM? Would you consider a garden tractor as a dedicated mower? Here's a thought.....when you are using the BH on the 2720, having a mower with a trailer behind it to collect the BH excavated material is very efficient. If the excavated material is to be used again as backfill, move trailer into place and dump....much cleaner. If the material it is to be relocated with the loader then this is a step you skip.....instead drive the mower and dump the cart to materials staging area and come back for more. There's a bright side to everything:D
Transfer tank (A61567)
3148 (A63117)
3148 (A63117)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
