Who else has luck like this.......?!
/ Who else has luck like this.......?! #1
scoutcub
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
Sooo there I was.....backing up my trailer up a slope to onload a tractor on my property. Left the truck/trailer, went and got the tractor. When I got to the trailer, I realized I didn't have the trailer quite centered on the trail, and would move the truck/trailer to make loading easier. Let the truck move forward a few feet, and angled the trailer a bit to center it up. Started backing up, but felt like the parking brake was on.....checked....no......spinning tires with empty trailer...hmmmm? What the hel...OK....put in 4wd.....now front tires are spinning as well.....WHAT THE HEl_??/
Get out, look around and this is what I see. There are 2 oil wells on my property, connected (used to be) to each other.....I caught the open end of the STURDY pipe and it did a perfect noose job.....got it so tight backing up nothing was going anywhere. Fortunately didn't hurt anything, just drove forward to "unnoose" it.....but what's the chances...????
/ Who else has luck like this.......?! #2
Scoutcub, that looks like something that I would do. I usually say, beneath my breath, "I couldn't do that if I'd tried"! Looks to me like you were trying to test your safety chains against some 2 3/8" upset tubing left over from your well.:D
/ Who else has luck like this.......?! #3
I wasn't so lucky. When I got out to see why the trailer wouldn't back up further, I discovered that the door of one of my other trucks was the problem.
/ Who else has luck like this.......?! #4
If it weren't for bad luck, I wouldn't have any luck at all! ;)
/ Who else has luck like this.......?! #5
yep.. one of those things you couldn't do if ya tried..
soundguy
/ Who else has luck like this.......?! #6
Right now I wish I had that good of luck..... If it had been me, that probably would have been the drive shaft wound up in the chains.:(
Ouch....OK ya got me beat!!
/ Who else has luck like this.......?! #8
Now go out purchase lottery ticket..never know,you got lucky before. ;)
/ Who else has luck like this.......?! #9
Wait! Is that a rear camera and back up sensors I see???
Yeah, but the wrong kind of luck! :laughing:
I was wondering if someone would snag me on that! :laughing:
I never even remembered to look at the back-up camera.....the rear sensors always go off with the trailer so I shut them off.
Good catch! ;)
I wish I had that kind of luck $$$$
Well, it sounds good, but........I have to split any profits with the previous owner......I've had several "no pay" months......checks for 41 cents.....guys driving on the property any time they need to.....etc.
We'll see if it pans out in the future, supposedly I get free NG to 1 residence when I build in the future.
/ Who else has luck like this.......?! #14
I knew safety chains were a bad idea.
/ Who else has luck like this.......?! #15
Unburied pipes around wells bite! Wait until you hit a flow line covered by grass with a mower. You can't make the tractor move fast enough. Pucker factor of 9!!
/ Who else has luck like this.......?! #16
yikes.. nat gas or propane around a diesel engine scares me.. too easy to make a runaway!
soundguy
/ Who else has luck like this.......?! #17
That and the thought of an exploding gas line under your mower.....
Luckily the well wasn't active. Took a day to trackdown the operator to let him know he had a 6" hole in a flow line and it would be a good idea to fix it and mark the line so it wouldn't happen again.
/ Who else has luck like this.......?! #18
double yikes!!!!
/ Who else has luck like this.......?! #19
Well, that was some good luck and them there are safety chains. It was good luck to discover the pipe in that way instead of it sticking through a $500 tractor tire and much safer to find the pipe that way than with the mower.
Fortunately for me, the pipes aren't hooked up at both ends, so no gas or oil in them. They are definitely becoming a menace, at least 4 separate places on the property I keep running into them doing groundwork, and they are TOUGH.....my dozer can't even bust em apart!
New/Unused Brush Cutter for Excavator (A61166)
New/Unused Brush...
2019 GALYEAN...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
