New guy: Ford 3000 questions
/ New guy: Ford 3000 questions #1
stagalv
Galveston - Texas
Ford 3000 Diesel
Hello - I'm new here and to tractors. I have a few questions about my new, 40 year old tractor. It's a Ford 3000 Diesel with the 8 speed transmission.
I have run the tractor for a few hours now with a rotary cutter and have become quite comfortable in it's basic operation. A while back I bought a reproduction owners manual and it shows this 8 speed version tractor available with two different PTO's. One of them had a two stage clutch where the half way down stopped the tractors motion and all the way down stopped the pto as well. The other one only had the pto turning while the tractor was moving.
Neither of these fit mine. On mine there is the clutch which only appears to have the all the way down position which stops the tractor only but the pto will continue to turn as long as I have it engaged.
Is this a common pto style or is something not working the way it should?
Also when I engage the pto I have the shifters in neutral and have the clutch fully engaged, idle speed and not moving it still grinds and then CHUNG, starts spinning the hog. Should I be doing something else?
I would appreciate your opinion on this.
/ New guy: Ford 3000 questions #2
You have an 8 speed with a two stage clutch. And the second stage, which is supposed to control the PTO, is not working. There are several possibilities.
1. The PTO disc is stuck to one of the mating pressure plates and not disengaging.
2. The transmission disc is worn and is using up more than its share of the mechanical linkage travel within the pressure plate. Reducing pedal freeplay to the minimum spec (or a little less) may allow the PTO stage to work properly for a little while.
3. The PTO disc has de-laminated and piled up between the pressure plates. Plate travel will not allow the clutch to disengage.
4. part of the mechanical linkage within the dual pressure plate has broken.
#2 or #4 are most likely.
There are a couple other scenarios, but you get the drift. Don't let anyone tell you that you have a single stage clutch or transmission driven PTO: you absolutely do not.
Can I keep using it like this? Big bucks to fix?
Thanks -
/ New guy: Ford 3000 questions #4
Changing the clutch isnt too bad and anyone with basic tools can do it. I did mine. I had to split the tractor though. I replaced the main clutch and the PTO clutch. Had about 200 bucks into it. Now if you have a shop do it for you, then add another zero onto that figure.
/ New guy: Ford 3000 questions #5
I thought 3000's had independent PTO's? It's a 3 cylinder right?
Wedge
/ New guy: Ford 3000 questions #6
if it had an sos it would have an independent pto.
in the 4000+ sereies you say the ind pto and 8spd.. etc.
soundguy
It's a 3cyl diesel.
Wow, so you think it would cost $2k to have it fixed in a shop?!
So what about my question above? Can I continue to operate it that way it is now? Is is that bad to grind a bit when I start the PTO? Should I start it with the PTO engaged?
This old tractor looks terrible but runs well now. I had basically an in frame rebuild done and a new injector pump a while back. It just suffers a bit in the ugly department.
/ New guy: Ford 3000 questions #8
soundguy
So the 8 speed 3000 had dual clutch?
Wedge
/ New guy: Ford 3000 questions #9
/ New guy: Ford 3000 questions #10
It's a 3cyl diesel.
I woud spend the money ($200) and fix it. If your only option is a shop then maybe trade it in on something else? 2k is a big investment for such a minor problem. I wouldn't continue to use it by grinding it.
/ New guy: Ford 3000 questions #11
You could probably find a shop to do it for 1200-1500 if you look. Its the labor that gets you.
Ok, thanks for the information.
My deal is that I keep the tractor 150miles away at a country property so it's not sitting in my garage to work on. Plus I can't bring it home as I don't have anywhere to put it.
/ New guy: Ford 3000 questions #13
try the adjustment on the clutch freeplay first and see what ya get.
soundguy
/ New guy: Ford 3000 questions #14
I've never posted here before so I hope I don't screw this up. I haven't been around the Ford's for many years, but doesn't the 2 stage clutch tractor's have a pin on the clutch rod with two holes in it. One position is for transmisson only and the other position is when you want to use the Pto. In this setting the cluch sets a lot higher, and work's the Pto. At least the 860, 861 ect. worked this way. Worth a look, correct me if I'm wrong.
Well, I didn't have an opportunity to fire up the old tractor but I did get to see her for a minute. I found out that I can easily lift up the clutch pedal about 2 inches from where gravity rests it. Is this the freeplay range?
/ New guy: Ford 3000 questions #16
no.. freeplay is where you push before you feel resistance.
/ New guy: Ford 3000 questions #17
I got 3000 ford, gas, 8 speed. The problem I have I cannot engage the PTO with clutch pedal all the way to the floor while engine is idling. If I stop the engine, the PTO level will engage the PTO shaft, i can crank the engine and the PTO shaft turns over the brush hog blades. so, do I have a problem with the 2-stage clutch, is plate "frozen?"
/ New guy: Ford 3000 questions #18
could be stuck or way out of adjustment.. or past it's service life.
have you set pedal freeplay?
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
2023 Bobcat T770 (A64126)
2023 Bobcat T770...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
Stout Buckets HD72-3 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
