When do you plug in?
/ When do you plug in? #1
wetstuff
Salisbury, Maryland
J-D 1070, Furgeson F-40
My 1070 is not a Chevy Volt .. but there appears to be a block heater plug hanging out the bottom of the front hood.. (I cannot see inside because the manual has not come for the tractor (Ebay purchase) .. and I cannot figger how to open the @#*! hood?!)
But, what's the general rule-of-thumb about what temps you would generally plug in a diesel. In WI/MN in the old days, we would only plug in a car when it was 'minus something'. Thanks.
Jim
/ When do you plug in? #2
i have a timer on mine.I set the timer for one hour a day.The hour before I plan to use it.I have a bunch of snow contracts that have to be opened up before 7:00 am.I set the timer for 3:45 am ,start it up 4:45 am and ready to leave for 5am.I leave it plugged in .For one hour a day I don't think it would bother the power bill to much.I quess the answer to your question is around freezing mark
Bear ... which is around your Zero. ..'0' and '100' are so much easier than 32 and 212. (once you get used to it..)
I can understand why you have a cab; it can be really tough in NB. I have driven the 401, T.O to Sydney, a number of times in the Winter. And Detroit to Toronto can be exactly like scenes in the movie FARGO. ...tough.
Jim
/ When do you plug in? #4
The hood release is on the right front corner (when facing forward) of the hood at the top of the radiator grill. There is a 2" lever there. Pull it straight out as you face the left side of the tractor. The hood will snap up a few inches. Raise it up by hand and set the hood prop rod, which is in the rear of the engine compartment. Look for the oil dipstick (check it), look for the fuel filter on the lower right rear side of the motor, check the battery water levels, and the radiator screen. The air filter can also be checked for excess dust and crud at this time. Battery cables don't last very long on this model in my experience. You might also want to check the fan belt condition and tension at this time. There is another fuel filter in the back of the 1070 on the right side at the bottom of the tank. Lastly, check the hydraulic fluid level at the dipstick at the rear center of the machine, by the upper 3 point link base.
I suppose you should check tire pressures, too. After greasing the steering, pedals and rear 3 pt linkages, you can check the radiator fluid. Then you will be ready for winter.
/ When do you plug in? #5
1070 hood opening from manual.
/ When do you plug in? #6
You will have to be the judge of this, but anywhere below freezing is a good idea. Oil weight, and how quickly you need to get to work can influence this decision as well as starting performance. A liquid type block heater supports quick combustion, warmup and cranking, but does VERY little for the oil in the pan.
I run a 5w30 synthetic in my 3720 and seldom if ever plug it in, but I also try to keep it inside in winter. I have started several small Deere diesels in sub zero weather without plugging in. I always leave them run at an idle for a bit to warm teh oil and hydraulics a bit and then begin operation at a very light load initially until things loosen up.
If you are doing a lot of cold starts an adhesive type oil pan heater (where practical) is probably the best investment you can make. The draw less juice, and heat the oil more than anything. Since heat rises they do a fair job of warming the upper end. A block heater does more for teh upper end, but again the oil is jelly and the fast combustion lends a false sense of security and lets you think it's ready for work instantly.
/ When do you plug in? #7
Wetstuf, a typical diesel engine will start unaided to 40-45 F, below that you will need Glow Plugs, Compression release, oil-Coolant heaters. The typical diesel oil is a 15w-45; you may want to consider a 5w-45 or a 5w-30 for the extreme cold. The operating temperature may never reach the normal green range; consider blocking half the radiator to get the temp into the green.
Z-6/J-5 ... I saw that rod sticking out the side, but when I pulled it - it just pulled?! Maybe I need to pull it that tick farther to activate the hood release...
That's it. I was rotating it to not avail.. then simply did not pull it out far enough. That nasty (now nasty) sound deadener will be the first thing to go - 'is all dust. Cute little engine, eh?! I printed out your instructions Z-6.
... and that "block heater" would have done about 1/2 our city block; it's very warm in the engine compartment. Looks like it needs a thermostat/timer. (35f. out with winds into the 20's..)
Bear ... I make stuff for aircraft, and oddly enough, I'll be sending a cover to a customer in Fredericton, NB this afternoon. Small world.
Jim
/ When do you plug in? #9
zero means zero celcius.sorry in canada we use metric.If you live in usa 32 F...The reason I have a cab is im tired of sweating my a>s off all summer and freezing all winter..Air cond in summer and heat all winter:thumbsup::thumbsup:
/ When do you plug in? #10
Had a lot of trouble starting my 955 over the weekend. It just turned over so sluggishly that it wouldn't start. I eventually had to place my propane-fired forced air heater under the tractor to blow warm air on the oil pan. Once it would turn over fast enough, it fired right off. I'm going to try switching to a synthetic oil and if that isn't enough, I'll put a block heater on it.
/ When do you plug in? #11
When it started getting below 25F at night,I plugged in the block heater. Fires up as quick as it did in 80 degree temps.:thumbsup:
Greg
/ When do you plug in? #12
I made sure my battery was fully charged on the 955 and tried it again tonight. It just won't turn over fast enough for it to fire. I've only the had the tractor for a couple of months and it did come from a warmer climate, so it's possible it has a grade of oil in it that is just too heavy for the climate it's in now.
I picked up some fresh 15W-40 to change it out to see if that helps any. Once again, I cannot believe what JD wants a simple blocker heater. :confused2: Since my engine is a non-JD Yanmar, I think I'll call the local Yanmar distributor and see what they want for a block heater.
/ When do you plug in? #13
First thing I do with new (used) piece of equipment is inspect/change the fluids especially the engine oil.
My 455 and 3720 will start unaided to well below zero. I don't make a habit of it, but have had to do it once or twice.
429888 (A61165)
429888 (A61165)
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
John Deere 4955 (A64119)
John Deere 4955...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
2011 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2011 Chevrolet...
