Snow Chains for 2640
/ Chains for 2640 #1
Rathpr
Member
I have new tractor using to move snow. Tractor has 18.4x30 tires that are starting to spin abd having hard time getting around. I am going to buy chains and am trying to decide between the ladder and duo-grip from tractorchains.com. I only need the chains for moving snow, does anyone have any opinions or experience with what may make a better choice. Thanks.
/ Chains for 2640 #2
I use the ladder style and have no regrets or problems with them in snow or on ice. And to me, an advantage is they are not so heavy to mount.
/ Chains for 2640 #3
If you use ladder chains they can be ruff on the road. I have ice chains that are like duo so I am always on chain, so smooth on the road and wicket traction.
/ Chains for 2640 #4
I am going to sound like a broken record but, the only chains I would consider recommending to anyone are the studded european style, aquiline and similar.
I also have a thread showing how I install chains, and I'm actually installing them on an 18.4-30.
/ Chains for 2640 #5
Having run v-bar ladder chains, then v-bar Duo-grips, and now studded European-style chains (all on the same tractor), I can definitely say the Euro-style are the best chains I have ever used.
The ladder chains worked OK for forward traction, but lacked lateral (side-to-side) traction. It was OK for my gravel driveway, but was a problem for me when operating on sidehills in my woods. These were 4-link chains, but the ride was surprisingly tolerable on hard roads (I had thought I would need to go to 2-link spacing to get an acceptable ride, but the 4 link turned out to be at least "acceptable".)
The Duo-Grip chains had great traction both forward and laterally, but I thought I was going to shake myself to death running down paved roads or on any hard-packed surface. If I were looking to drive only off road (softer surfaces and mostly slower speeds), and wanted to save a bit of money over the cost of the Euro-style chains, I could have lived with these.
My current Euro-style chains (Ofa Eko 8) have very good traction both forward and laterally, and are smooth going down hard roads. They are what I should have started with all along. I suppose the studs could be a problem if I spun them on pavement, but that's not an issue for me, since I don't have any pavement. (They are not a problem just driving down a paved road. I've never tried pushing snow on a paved road, so don't know whether that would be an issue or not.)
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2025 Kivel Quick Hitch Skid Steer Attachment (A61567)
2025 Kivel Quick...
2018 Ford E-450 Shuttle Bus (A61568)
2018 Ford E-450...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
