Best catagory 1 quick hitch ?
/ Best catagory 1 quick hitch ? #21
Had a landpride that was VERY well built but sold it when I got the Pats ez hitch. That was a much better set up though the quick hitch was still pretty good. I did have to modify my box blade. The box blade had a metal lip that protruded under the pins. Not a problem with a conventional lower arm but it was in the way when you have to come up from underneath. I had to cut away a slot to allow the "hooks" on both the quick hitch and Pats to engage from underneath. this was the only implement I had to modify.
/ Best catagory 1 quick hitch ? #22
/ Best catagory 1 quick hitch ? #23
The post wasn't directed to you although you chose to reply to it as if it was.
There are a few people out there that would like to be able to hook up everything they come across - even implements shared by or with a neighbor.
Not all folks have the time, skill, desire, or brand loyalty to work over all, or most, of their equipment to 1/2" tolerances.
Then there is the issue of those of us who have both Cat 1 and Cat 2 attachments that share among tractors.
Just one more thing. Some of the top link hook ups on an implement have a support just under the pin that prevents hook-type quick hitch top links from attaching from below.
Your original post was not directed any one person since you did not include a quote...it was a broad sweeping comment that you stated as fact.
/ Best catagory 1 quick hitch ? #24
Here is one I documented on my chipper: New-to-Me Goossen Chipper/Shredder - TractorByNet.com Hope that helps:thumbsup:
Nice example, thanks again....and that chipper is awesome. I don't ever see stuff like that for sale when I'm out driving around, but I keep looking! Anyway, it doesn't look like modifying things to fit a quick hitch is that big of a deal, honestly. I guess it depends on your "modification skills" and what you are willing to do to make it work. I've seen a few posts and reviews where people get really mad because their stuff doesn't work perfectly with these quick hitches right off the bat. I don't see it as a big problem. thanks again for the info.
/ Best catagory 1 quick hitch ? #25
Nice try. Mine was the third post and used the pronoun "you" so was obviously responding to the OP. Choosing to read it as "everyone" was your choice.
The OP stated that he/she has several different implements to attach to the tractor. It is a fact that some implements are not made to exactly match the tolerances of a particular frame-style hitch. You found that out as fact since you had to modify several implements to fit your Deere quick hitch according to your own words.
In my second post (#18), details of why disappointment was likely were explained.
Nevertheless, there is no point in engaging in a pi$$ing contest with you. You are happy with you setup and that is the bottom line. My point is that the OP will most likely be happy with a quick hitch system that can conform to a variety of different implements that may not be constructed to the specific standards required by frame-style quick hitches.
As far as "disappointment" is concerned, it is very likely that you were pleased with the implements that fit right up to your quick hitch and "less pleased" with those that did not. It is a matter of semantics.
And yes, I have owned and used a couple of frame-style quick hitches. Also owned are a variety of implements, some home-made, that do not conform to standard measures. Rather than modify them all, the simple fix of using the Pat's system was chosen.
BTW, I try not to quote unless necessary to save bandwidth and clutter (like this lengthy post turned out to be).
Done.
/ Best catagory 1 quick hitch ? #26
Have had the Deere iMatch all the years they've been on the market, and can't see improving on it. There are other systems, like Pat's, that go just part way to the ideal quick hitch. Ones where "you" don't have to get off the tractor to hook anything up.
Unfortunate that the subject has what is the "best", and that solicits just opinions which every one of us will have to offer. The OP can sort out what is "best" for him/her.
My iMatch rarely is removed from the tractor, as only a recently purchased rotary tiller doesn't "match" the imatch. Am looking to trade up to a tiller that does.
Whether the OP buys quality or gets by with chinese made, is up to him/her.
But be happy with what you have, nevertheless. :D
/ Best catagory 1 quick hitch ? #27
I am very happy with the IMatch setup, saves me alot of work changing implements.
/ Best catagory 1 quick hitch ? #28
Careful Steve...you will get disappointed in it soon :laughing::laughing::laughing: clock's a tickin"
/ Best catagory 1 quick hitch ? #29
Kenny I am thinking about putting one on my X749 too.:D I should finish the 3pt install on it over the weekend.
/ Best catagory 1 quick hitch ? #31
Could you go into details why it did not work?? I'm thinking about Pat's but if it doesn't work on everything... forget it.
The shape of the ballast box is the problem. The box is narrow at the bottom and wider at the top, just above of the pins the box begins to taper up and this taper does not allow the Pat's to connect. It is not a fault of the Pat's but rather poor design from Kubota. I've considered looking for a JD ballast box since they appear to be square/rectangular and the Pat's would work fine.
If you would like a pic let me know, I'm heading up there tonight after work and can snap one.
/ Best catagory 1 quick hitch ? #32
I'm ALL about photos!!! My middle name is photograph... So... yes, photos, please... :thumbsup::ashamed:
Actually, does anyone have Pat's with a King Kutter Rototiller??? Does it work?
/ Best catagory 1 quick hitch ? #33
Yes and yes. It works very well.
Remember that the PTO shaft will need to be extended another few inches because the Pat's sets the mounting point back a bit farther. There should be enough extra length on the present shaft. None of my PTO shafts had to be replaced with a longer one because of the Pat's.
A longer top link MAY be necessary depending on how your tractor is set up. They are cheap at Tractor Supply.
/ Best catagory 1 quick hitch ? #34
gwdixon, how about a phot of your Pat's I see some different types or knock offs on ebay? I would like to buy the right type the first time for my Bota? D.
/ Best catagory 1 quick hitch ? #35
I found a lot of pictures on pats website
/ Best catagory 1 quick hitch ? #37
I don't mind photos but the Sticky at the top of this forum has a lot of info and some photos already. Mine would be a duplicate of what is available. There is not a lot of difference.
Two of my Pat's were bought off eBay and one from the TBN web order.
/ Best catagory 1 quick hitch ? #38
Now a "Pats" is like the Power traction hitches on my bigger Olivers. Right? You still have to get off the tractor to attach the top link? Honestly... How is that better than a quick hitch? Of course.... I understand this is only IF your implements are quick hitch compatible. Don't get me wrong, to each his own. Just curious.
/ Best catagory 1 quick hitch ? #39
wny770 we find the speed and safety afforded by Pat's Quick Hitch makes it a must have item. We have helping kids. Hopefully 50 years from now they will remember to be as safe as possible when hitching equipment.
For the person who can afford to go buy only equipment trained to work with their quick hitch system they do not need Pat's Quick Hitch.
For the rest of us Pat's Quick Hitch is about as good as it gets. There are cheaper options on Ebay that work for some but we have 60 HP Cat 2 tractor with a very heavy 7' bushhog. Pat's Quick Change hitch has proven itself over this past year as a strong yet easy to use hitching system that works well for any of our 3 point hitch equipment.
/ Best catagory 1 quick hitch ? #40
There are some implements that interfere with you bringing the hitch up from below [my tiller]. So pats allowance that you can swing them on from outside is valuable there. Also, no width constraint like QH.
larry
