Now that I have it!
/ Now that I have it! #1
Jw5875
Gold Member
NW Pa.
Kubota L3400
I just had an 18 = 1 gearbox given to me with the PTO shaft. Gent stated that is is from a portable saw mill?
Give me some ideas for a winter project!!
Kinda thinkin rotary for aluminum christmas tree! (need the color wheel/light)
rotating laundry hanger/dryer
merry-go-round
jw5875
/ Now that I have it! #4
How about a sand/salt spreader for your driveway. It could double as a fertilizer spreader.:thumbsup:
/ Now that I have it! #6
Clean it up for starters and make sure it works properly before investing time and money into making it do useful things down the road.
/ Now that I have it! #7
Hi
These old gear box where used with tractor without the side belt drive to operate machines that needed the long and large belt to run.
/ Now that I have it! #8
You may be able to turn it upside down and make a post hole auger !!!!!!!
/ Now that I have it! #9
Donate it to a museum? Just kidding. It looks pretty old. Is that a breather on top?
18 to 1.... I would hold on to that,doesn't take up much room and it ain't like you can get another at Walmart.
I'm thinkin you should move water with it somehow or another....
/ Now that I have it! #10
I can tell by the chalk marks that you counted the turns to get the 18:1 gear ratio. But it sure does not look like one gear is 18 times the size of the other. Is it a double reduction or worm gear?
/ Now that I have it! #11
18:1, so about 30 rpm at 540 PTO speed.
The drum looks to be about 12" diameter, so about 100 feet per minute, if you were to take a few turns around it with a rope.
Hmmm.
Sounds just about right for the capstan log winch I have been wanting to make.
-Jim
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2019 JCB 457 (A60462)
Jack Daniels Mini Decorative Truck (A61574)
Jack Daniels Mini...
208320 (A58375)
208320 (A58375)
2015 Hyundai Veloster Hatchback (A61574)
2015 Hyundai...
