Now that I have it!
/ Now that I have it! #1
Jw5875
NW Pa.
Kubota L3400
I just had an 18 = 1 gearbox given to me with the PTO shaft. Gent stated that is is from a portable saw mill?
Give me some ideas for a winter project!!
Kinda thinkin rotary for aluminum christmas tree! (need the color wheel/light)
rotating laundry hanger/dryer
merry-go-round
jw5875
/ Now that I have it! #4
How about a sand/salt spreader for your driveway. It could double as a fertilizer spreader.:thumbsup:
/ Now that I have it! #6
Clean it up for starters and make sure it works properly before investing time and money into making it do useful things down the road.
/ Now that I have it! #7
Hi
These old gear box where used with tractor without the side belt drive to operate machines that needed the long and large belt to run.
/ Now that I have it! #8
You may be able to turn it upside down and make a post hole auger !!!!!!!
/ Now that I have it! #9
Donate it to a museum? Just kidding. It looks pretty old. Is that a breather on top?
18 to 1.... I would hold on to that,doesn't take up much room and it ain't like you can get another at Walmart.
I'm thinkin you should move water with it somehow or another....
/ Now that I have it! #10
I can tell by the chalk marks that you counted the turns to get the 18:1 gear ratio. But it sure does not look like one gear is 18 times the size of the other. Is it a double reduction or worm gear?
/ Now that I have it! #11
18:1, so about 30 rpm at 540 PTO speed.
The drum looks to be about 12" diameter, so about 100 feet per minute, if you were to take a few turns around it with a rope.
Hmmm.
Sounds just about right for the capstan log winch I have been wanting to make.
-Jim
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2011 Toro Multi Pro 1250 Gas Sprayer Cart (A59228)
2011 Toro Multi...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
