New 2320, I'm frustrated
/ New 2320, I'm frustrated #1
firstgencamaro
the middle of the oilfield in ND
It's a really nice day so I figured I'd try to mount the 62" mower under my new 2320.
I quickly realized I do not have the front bracket to mount the mower. The salesman told me all the stuff I need is there to mount it but he is WRONG, I need the LVB24899 bracket to get it hooked up.
Then I figured I'd use the 647 tiller that they had already mounted on the tractor. I made it a couple feet and the PTO driveshaft slipped apart at the center spline AAARRRRGGGG.
I'm assuming it is the wrong shaft or I need a spacer or something?
All I know is that it is WRONG.
I sure hope the snowblower is right.
/ New 2320, I'm frustrated #2
I'd call the dealer, have them come to your house and get it right. I would think the dealer would have mounted the MMM before delivery.
Dealer service seems to suck on just about everything now a days.
I love the tractor but the sales/service experience so far has been the worst I have ever had. I waited several months and from what I can tell the snowblower is the only thing they got right. The mower and tiller are both incomplete and/or wrong parts used.
Does anyone know if the pto shaft on the tiller has a part number on it somewhere?
I tried to call the salesman all last week and I left messages for him to call me back, I still havent heard from him.
So far I need
1- the front bracket for the mower
2- the correct pto shaft for the tiller
3- independant lift kit and attaching parts for the mower
4- manual for the mower that they didnt give me
5- manual for the snowblower that they didnt give me
I think the snowblower is done correctly but I will not be surprised if parts fly everywhere when I try to use it after my experience with the other two attachments.
I guess maybe 1 out of 3 being correct isnt bad haha
I should also mention that from here on out I will be doing the work on the tractor myself.
I told them from the start that I could mount everything myself if they just bring the parts I need to do it.
They have proven to me that if I want it done right I should just do it myself.
/ New 2320, I'm frustrated #5
I bought a FEL in a crate and installed it myself on my BX, but it wasn't purchased at the time of the tractor.
But if this was a new package, I personally don't quite understand why all this wasn't assembled and checked out at the time of delivery. Seems a bit odd, that's all.
/ New 2320, I'm frustrated #6
I'm gonna still leave it at "congrats, that's a beautiful rig" and hope we hear something positive from you soon.
A week of messages and no response from dealer. Have you considered calling the manager at the dealer?
Good luck!
/ New 2320, I'm frustrated #7
So far I need
The rear PTO shafts are generic, and often to long so they need to be cut to fit properly-sounds like they cut your to short OR you added an iMatch after the fact which move the tiller rearward about 4". You can but an extension shaft for about $20, but they need to get you a new shaft.
1. Since you have the front QH (quick hitch) for the snowblower, they you should already have the LVB24895 bracket, it mounts up between the frame rails with the same 8 bolts that hold the brush guard. To mount the MMM you will need part # LVB24899, it hangs in the LVB24895 bracket and provides the support for the front draft arms of the MMM. Without the QH, there are just two simple brackets mounted-but you have to remove them when you attach the LVB24895 that holds the QH.
2. See first paragraph
3. That I cannot help with, I am only familiar with the regular lift tied to the 3PH.
4. OMLVU17638_G9
5. Not available online, sorry.
/ New 2320, I'm frustrated #8
I found good pictures, posted by Green4me on MTF:
/ New 2320, I'm frustrated #9
At delivery the dealer should have provided all manuals and showed you how to mount and dismount all attachments. That's how I would do it if I were a JD dealer.
/ New 2320, I'm frustrated #10
You need to review this video on PTO shafts, Measure and Cut Tractor PTO Shaft - Everything Attachments.com how to measure to insure you have the correct one installed. I would view the video, make the measurements as described and then talk to the dealer, not salesman, not service manager. Several people have damaged the PTO, rear PTO gear box and housing with an improper PTO shaft. You were lucky if the only thing that happened was the PTO shaft separated.
When the tractor was delivered the tiller was already mounted and I didn't change anything. I do not have the Imatch, I tried to use it as delivered. I just assumed it was correct.
I also found the part # of the bracket that I need (LVB24899)
I told the salesman about the issues and told him I have the part# for the bracket, he said he does not need the part# and they have a bracket for me that he forgot to bring with him.
He said he would try to figure out the issue with the shaft.
I have my fingers crossed.
/ New 2320, I'm frustrated #13
I think that is the wrong driveline assembly. If you look at the parts for the 647 A/B tillers it uses the three spline(?) tubing. My 673 has the 3 spline tubing also, haven't seen that multiple spline tubing you have pictured on any of my implements from Deere so far.
I looked up your tiller in JD Parts to verify this.
/ New 2320, I'm frustrated #16
Had a Holley on one of these in 1969-70. Loved gas and needed wings.
/ New 2320, I'm frustrated #17
Sounds pretty frustrating that you are missing a part up front and then the dealer has been slow to return phone calls. My 2305 was delivered with the mower deck already attached so I was safe to assume all the parts were there. I think having it already attached also made it easier for me to figure out how to dismount and remount the mower deck in the future.
I haven't had a lot of experience with PTO attachments outside of the MM mower deck, a PHD and a spreader. I know on the mower deck, the shaft on it has a collar that has to be "cocked" in order to snap on and make connection with the tractor PTO. Maybe you have already done it, but I'd take a second look at how your tiller's connection is with the rear PTO.
Good luck with getting your issues resolved. TBN is an awesome source of knowledge from lots of people willing to share.
/ New 2320, I'm frustrated #18
Kenny G I know this tread is 3+ years old but thanks.
I just bought a used blower with quick hitch and needed these picture to straigthen myself out!
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
1999 INTERNATIONAL 4900 (A67714)
1999 INTERNATIONAL...
PORTA POTTY (A67714)
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2023 Giant G2500HD Mini Articulated Wheel Loader (A66734)
2023 Giant G2500HD...
WACKER NEUSON LTN6 LIGHT TOWER (A65056)
WACKER NEUSON LTN6...
