Repaint YM2000
/ Repaint YM2000 #21
sealed bearings to replace my grease packed bearings?
I don't think there is a need to upgrade the bearings in typical American farm use. Does anybody here run in water like this?
The photo is from Yanmar-Japan's website showing typical applications.
/ Repaint YM2000 #22
"If" you have the tapered roller bearings I don't believe they are available as a sealed bearing.
/ Repaint YM2000 #23
IMO.If that was true I believe this would not be a Roller Bearing. This is off a RS1400 Which is sold new for the Ym2000 which is always totaly submerged in water and ALOT more rpm's and Wear.
Carey
/ Repaint YM2000 #24
Can't tell for sure but that doesn't look like a tapered roller bearing, looks like a ball bearing. Tapered roller bearings are made to be adjusted such as is on a trailor axle, etc.
/ Repaint YM2000 #25
yea i think that is a ball bearing bearing that is packed with greese. the guy who posted here a few weeks back about his sheet metal falling off his tiller, he had one like that did not have a cover on it.
/ Repaint YM2000 #26
My point being Either Or they are not sealed. This is the type of bearing you are refering to.Which My Bass boat trailer uses. There not much better. I was coming home one night from Okeechobee.Fl. and was 20miles from home and lost a Wheel/Hub which took out the spindle also. No cell Ph. Coverage back then and had to leave it at 2am in the morning on the side of the road.That Sucked Big Time:mad: I even used Bearing Buddies that I checked before leaving. The trailer was made to be submerged but still far from water tight.:confused:
Carey
/ Repaint YM2000 #27
Neat,
Did you order these from a Yanmar dealer or did you just go to the bearing house? You still dont have those part #s do you?
i bought it all from bearing wholesalers here in australia. i am sure you have something like it over there. the bearings were 6204-2RS and 6205-2RS and the race washer was 1mm thick. had to use this otherwise it was sloppy when tightened up. has been good since the replacment.
/ Repaint YM2000 #28
Thanks for the info, now i can refer back to this post when i get around to digging into it.
/ Repaint YM2000
Agh race washer, I think I threw that away. Because new bearings were different.
/ Repaint YM2000 #30
That is the type of a bearing I am setup with also Neat 1500 is refering to and there is a race washer also. You may want to put those back ShawnJVL won't be much to it ;)
Carey
/ Repaint YM2000
I got the Wheels finished, started trimming in the motor and insides of various parts. I'm Painting the Frame black, I want to be able to touch up with a black spray can if I get any bumps or bruises. Also to make look newer like the USA model yanmars.
/ Repaint YM2000 #32
Now this is a guy serious about a paint job. Looking good! :thumbsup:
/ Repaint YM2000 #33
What color ist he frame/motor going to be? I see that you painted the motor black and frame the yanmar green. Are you going to keep this arrangement or say with one generl color?:confused: Those rims look brand new, so do the tires. Great job! :thumbsup:
/ Repaint YM2000
/ Repaint YM2000
I got the Frame, Motor Painted today. Heres some Pics :cool:
/ Repaint YM2000 #37
Nice job! :thumbsup::thumbsup:
/ Repaint YM2000 #40
I used Valspar hardener with gloss Rust-Oleum to paint a horse trailer and it did a great job... even with a roller
1996 International 3800 School Bus (A64194)
1996 International...
2022 EZ-GO ELITE...
2012 Ram 1500 Crew Cab Pickup Truck (A64556)
2012 Ram 1500 Crew...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
2025 Good Luck Go Cart (A64557)
2025 Good Luck Go...
