l3400 oil capacity! !
/ l3400 oil capacity! ! #1
swampvol
Gold Member
SC
Kubota l3400HST TLB
No matter how warm I let her get before dropping the plugs, no matter how long I let her drain, I still can only get 5 quarts in!
The manual says 6 qts., but either the manual is wrong or my dipstick is.:mad:
/ l3400 oil capacity! ! #2
My WSM says 6 quarts with a filter change, If you are not changing the filter you are right on the money:thumbsup:
/ l3400 oil capacity! ! #3
Are you removing both of the drain plugs?
/ l3400 oil capacity! ! #4
Are you removing both drain plugs and filter??????????????
Yep. Both plugs, and a new kubota filter.
/ l3400 oil capacity! ! #7
I'm sure that you are aware that not all jugs of oil are 1 gallon any longer. Some are 5 quarts or 5+ quarts. Make sure that you did not use a 5 quart jug thinking it was a 4 quart jug. I did have a friend who made that mistake.
/ l3400 oil capacity! ! #8
When I bought my L3400 it showed overfull on the dipstick. I changed my oil a couple weeks ago and used a Kubota filter. I removed both drain plugs and let it drain completely. I put in exactly 6 quarts per the manual and like yours it shows overfull.
I am going to leave the 6 qurts in there. I thought it was just my tractor. Guess not. Brian
/ l3400 oil capacity! ! #9
This is exactly what happened when I did the first oil change on my L3400. I drained some out so it was correct on the dip stick.
Now when I change oil I put in 5 qts and then after running, I add until full.
/ l3400 oil capacity! ! #10
I am guessing the total to the full mark would be about 5 1/2 quarts? Brian
/ l3400 oil capacity! ! #11
5 & 1/2 Qts. That's pretty close.
