8540 Is Here! Picture
/ 8540 Is Here! Picture #1
Brandon1107
Member
South Texas
Kubota M8540
Hello All,
Well I have been reading for a while and joined recently. This is a great forum. I based my decision on what 3 or 4 guys said on here, thanks to all that post what they have experienced. (rjkobbeman and TripleR) It seemed all my questions were asked and or answered before I posted them.
This is my first Kubota, it beat out Deere due to price and dealership personnel attitude.
M8540HDC-1 Cab 8-8
The size and cab were chosen to run 15' batwing. I have owned Fords, NH and a Long :mad: before.
This is also my first tractor grapple and 3rd funtion so I have a few questions. I made my decision on grapple size without researching it here but clearing fencelines is something I want the ability to do. I have read on here that most people run there tractors revved pretty high when they use the FEL (PTO speed or near). I have been using my grapple for most of the day clearing scenderos and blow-downs, and I am slowly getting more proficient with it. My issue is that this grapple is a beast and when the lid comes down it is violent! If it makes it closed on metal the whole tractor will shake. With the third function valve I don't have the option of feathering. So is there a way to control flow that will work efficiently or is anyone out there using foot throttle to alleviate this? I know that this is a large grapple and may be too much but the performane in my opinion has been great.
ti5cmr
/ 8540 Is Here! Picture #2
Look into a putting a flow restrictor in the grapple circuit to slow down the movement. Also, I would think you could do most of your loader work at not much above idle. It should have plenty of hydraulic flow and pressure at low rpm. By the way, congratulations on an awesome tractor and welcome to TBN.
/ 8540 Is Here! Picture #4
Very nice tractor.:thumbsup:
I would love to have a grapple, but $$$$$$$$$
I have never used a grapple, but I don't run any of my tractors at PTO speeds when using a FEL as they work well at much lower RPM's and I dislike the the way the loader jerks and reacts at this speed.
I use the foot throttle a lot while doing FEL work with my M8540. I don't vary engine speed as much on my L5030 due to the HST, but do for transport and run it at about 1500 or a little more.
Experience will show which works best and I am still on the learning curve with our M8540, but love it.
/ 8540 Is Here! Picture #5
Congrats on your new Bota! :thumbsup:
/ 8540 Is Here! Picture #6
Most of the time I use the foot throttle.
When I am using the PTO, I set the hand throttle for PTO speed.
In some cases I will set the hand throttle when I am using the FEL, but I normally set it to 1,500 RPM. This gives me enough engine RPM to not stall (I usually am doing this when I am in less than ideal terrain and I am using the brakes... and want to back up without having to use my foot on the throttle.) A little extra RPM also works the hydraulics better/faster. It doesn't take much RPM above idle to get the pump working good though.
You certainly could leave your hand throttle off and use your foot only. This would allow you to take advantage of slower hydraulic flow at idle.
/ 8540 Is Here! Picture #8
Sweet machine!!,no need for high rpm's for a grapple...you can install a flow control on the RETURN side of the cylinder to slow it down on close.I use a Green's machine thumb and markam tooth-bar ,works great.:thumbsup:
/ 8540 Is Here! Picture #10
Very nice !
I use my 3rd function for a post hole digger, bring your RPM down when you hit the button. You will be surprised at how much that helps.
Enjoy !
E/S
/ 8540 Is Here! Picture #11
That is one nice machine. You will enjoy it I am sure. I keep reminding my wife to take some pictures some when we are working, but she forgets the camera... oh well, next time..
Wow what a difference. Just for an update and in case anyone else reads this looking for answers: I am now running the hand throttle at 1100 rpm and work in second gear. While working brush I use low range then when the grapple is full and I need to drive to the pile I put it in high range. I am loving the shuttle shift.
To all the compliments: Thanks!
No buyers remorse here.
/ 8540 Is Here! Picture #14
Very Nice monster you have... I am way jealous:thumbsup: send some more pics in with a car or something in those jaws:thumbsup:
AndyG
/ 8540 Is Here! Picture #15
The more you use it, the better you will like it. I kind of miss the end of mowing season.:laughing:
/ 8540 Is Here! Picture #16
Very nice !
I don't see why it would be hard to put a regular spool valve in the third function line....although maybe that's just me; does anyone know? Until I read this thread I didn't even know that my 3rd function didn't feather because I've yet to use the 3rd function (aux front hyd) on the M59.
Also, put me on the side of the low RPM tractor guys. Ever since tractors started using variable speed diesels about 30 years ago I've been running all mine at 1500 rpm or even a little less. We never lug them, just don't rev them to max. Much nicer to live with. We hardly ever find a reason to go to full rpm.
rScotty
/ 8540 Is Here! Picture #17
I just bought a rake grapple. $1375 shipped. Works good and has 5 yr warranty. Got in 3 days after ordering it.
/ 8540 Is Here! Picture #18
Mine is a 60" on an L4400. I have the skid steer upgrade on my loader. They have larger grapples available (72") if you are interested.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A64553)
2006 Snorkel AB50J...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
