Engine ideas
/ Engine ideas #261
Here is some pic from Richards
/ Engine ideas #262
The Weather looks Good this week end.:thumbsup:
Well Hope to see you all Sat Oct 9 Th or Sunday Oct 10
The HIWASSEE VALLEY ANTIQUE TRACTOR meet the second week end of Oct .
So this year look like 9 and 10 Oct 2010.
We meet at Charleston TN city Park
Charleston is about 70 Miles south of Knoxville
Exit 33 on I 75.
From Chattanooga Tn is about 30 miles
There is a trailer park
at exit 33
The motels are about 5 to 10 miles at Exit 27 At I 75
/ Engine ideas #263
Nice pictures Bruce. The first one is Richards 'booth'. Just to the right is a trailer where he had a large circular saw blade (used) he was trying to sell along with a log splitter attachment. Another guy there had a stump grinder attachment for sale. For those of you who have never seen the log splitter or stump grinder in action there are videos of them on you-tube. Dont have links but type in Gravely and search. The videos are amazing - the Gravely makes quick work of logs and stumps!
/ Engine ideas #265
what time did you get there?
I got about 10: 30 to 2:30.
Did I get any Pic of you?
Got there at 1:15. Kept asking people if you were there. Everyone told me you were there in the morning. They looked around but didn't see you. I was wearing an organge Tennessee football t-shirt. Next time will have to get your cell number and call when I get there. I stayed a couple of hours.
/ Engine ideas #266
We Had a great week end at the Southern get together.
Here is some pictures
/ Engine ideas #267
Hi Guys
I finally got a gear done for the L model that I think will work.
I will use a top hat or bushing on the end like Gravely uses
on the late model.
I took a gear Martin S1015
and a 1 inch coupling bored the coupling out left about .002 small.
Pressed the gear hub into the coupling with a key all ready in coupling .
Welded them together.
Bored the gear end out so engine crank shaft can go all way through.
Also machined a pocket in the gear end for the top hat to fit.
Machined off to fit on the engine shaft length.
Now all I like is having it harden.
and make the top hat and have it harden. :thumbsup:
Well finally I got my print done and have been trying to get prices.
/ Engine ideas #268
I finally got the print done so now to get prices
I am getting made out of 4140 steel 1 piece no welding
Hardened and ground inside and out
Looks like it will run about 125. to 150.
  • 045 GRAVELY MODEL L & C10 INPUT GEAR.pdf
/ Engine ideas #269
Hey Bruce - would you still need the 'top hat' with this or is it all one piece?
/ Engine ideas #270
Yes there are 4 pieces.
1. Top Hat
2.Gear is 3.00 inches long
3. Spacer 1.590 thick
For $250.00 plus it was higher then I hoped for.
4 . Kohler adapter .500 thick
I am suppose to have 10 each gears Friday week.
Made whole from 4140 steel hardened and ground
/ Engine ideas #271
Hi! Congratulation ! Very good work Bruce . I have a BCS a Grillo and a Gravely L model . The best tranny is on Gravely True Shuttle live PTO very reliable. A Masterpiece of engineering. So Gravely are very valuable tractor for rebuilt with a new engine. Good Luck! Oldmech
/ Engine ideas #272
Thanks Oldmech
I will have 10 of these gears by Friday
Boy we have talked about this for 3 Years.
I have a C10 That I am going to put one as soon as I get them.
Because it has the same gear as the L model.
I will show pictures.
thanks again.
/ Engine ideas #273
gravelymay,
I need to repower my Model L. However, it only has a 2-speed transmission. Will a modern engine work? Will you also be making adaptor plates? I would really appreciate any help you can give (or sell - if you are willing sell the parts you are making).
Thanks,
Greg
/ Engine ideas #274
Hi Greg
Right now I have the adapter thickness nail down for the C10.
I am using the old Kohler adapter and making a spacer .
Because the 1 inch cranks are longer.
Now to the L Models.
I plan to use a old Kohler adapter plate redrill it to fit the Model L Transmission
I have not nailed down how Thick the spacer will need to be.
The gear I am having made will fit on all the 1 inch engines.
Some will be different lengths
So I will have to come up with different spacer thickness
Yes I plan to sell the
Spacer ,Gear,and the pilot bushing.
These 3 pieces will run $250.00 plus about $15.00 shipping
The gear is 150 by it self
The spacer is made from a 8" round 2" thick
So it is not cheap.
I can get the muffler cut out for $40.00 swap.
/ Engine ideas #275
Hey Bruce - cant wait to see how this works on the C10. On another note, think we discussed this once before somewhere - is it possible to shorten the crank on a 13 HP clone without removing the crank? Think you told me this is possible. If so, how would you do it and still keep the new face exactly perpendicular to the shaft?
/ Engine ideas #276
You would have to have the crank turning.
So you could start the engine and use a slitter blade.
On a 4 in side grinder.
I would drill and tap the hole deeper before you start.
/ Engine ideas #277
Here is a C10 repowered with a old Honda engine
I had to notch the muffler also.
The engine and transmission is still dirty.
but the picture will give you a Idea how they fit.
/ Engine ideas #278
Never heard of a slitter blade. Does this have fine teeth? Do you hold it by hand? I assume the 4" side grinder is an angle grinder? Just trying to visualize how to do this. What spurred this is the cranks on the Honda/Clones are typically much longer than they need to be for Gravely repower. So why not cut the crank down and eliminate some spacers? That would work for what I did.
Also - the C10 photos you just posted - is that an old project or one you're doing right now? Thanks.
/ Engine ideas #279
This is the C10 That I just got in to change
To a old Honda that he Had bought at flea market for about $150.00
So I am not cleaning it up except where it mounts up.
Here is a picture of a speedy cut .
I am using on a trailer frame to cut gaps.
/ Engine ideas #280
Hi One
Did you understand what I was talking about?
The side grinder Has a slitter or speedy cut blade.
The blade is about 1/32 thick grinding cut off type blade.
Will cut anything Hardened Steel ,Stainless steel.
Just don't get anything in the way you don't want cut.
I didn't get my gears yet.
He was having a problem with the dead end broach.
So he had to order a new one.
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2014 FORD F-150 (A60736)
2014 FORD F-150...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2015 MACK PINNACLE DUMP TRUCK (A60736)
2015 MACK PINNACLE...
3015 (A56857)
3015 (A56857)
