Loader Procedure for attaching loader to BX
/ Procedure for attaching loader to BX #21
guys,
what happened to the video on the "Bxpanded," website? did it get moved?
D902
/ Procedure for attaching loader to BX #22
ALSO IN THE VIDEO, the arms of the f,e,l pop up to high,rpms way to high,i just move mine maybe a inch above the holder,makes reinstalling a breeze,on and off,about 4 minutes BX2660
/ Procedure for attaching loader to BX #23
When my tractor was delivered this summer, the driver showed me everything on the tractor, including taking the loader off and putting it back on. He would have unhooked hoses but I told him no need. He was at that point, even showed me the relieving the pressure before unhooking...
If you are still having trouble, perhaps you can find someone locally that does it well and have them show you, then you do it. I was not sure I would take mine off and on much but it is not that big of deal, makes using or not using it a non-issue. If it is off and I need it, I take a few minutes and put it back on..
Of course if you are running other front mounted implements, it may take a few minutes to remove the other and install the FEL, but most should be just as quick.
/ Procedure for attaching loader to BX #25
Interesting. The video shows the removal is done with the tractor still running, i..e the hose disconnect.
/ Procedure for attaching loader to BX #26
You can re-install with the engine running as well.
We should have taken the video from the other side. We'll do another one sometime. All the activity on the other side of the tractor is the fiddling with the plastic plugs and caps.
Finally finished lawn season and got back around to the loader. The floor of my garage slopes down so I had real difficulty getting the pins to line up again to reinstall the loader. Eventually I was able to solve the problem by rocking the bucket back and forth and wedging enough wood underneath to raise the bucket level up and line it up with the tractor. The job should go much faster next time.
Thanks for all the comments.
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2022 EZ-GO ELITE...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2338 (A65055)
2338 (A65055)
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
