Trouble loading TBN today!
/ Trouble loading TBN today! #1
DaveOmak
Omak, Washington
'53 Jubilee
Well, after an hour or so, I finally got this forum open.
Initially, went to my fav's and clicked on TBN. Nothing happened. Blank page.
Opened Google. Searched "Tractorbynet". Clicked etc and "BING" opened. Clicked on TBN on the "BIN*" search page and "B" reloaded again. Could not get here. Reopened browser. Started all over trying to get to TBN. COULD NOT GET HERE.
Now I'm getting all warmed up as if the dog ate my lunch.
Has MS* messed with my search stuff AGAIN? A few years back they kept deleting my GOOG*** favorite.
Anywho, finally I did a search on Goog*** for
"tractor forums". TBN came up. Clicked on it and VOILA!
Here I am.
All my other fav's worked fine.
Has anyone else experienced a problem of this sort?
/ Trouble loading TBN today! #2
Here I am.
I had a similar problem earlier this morning with both Firefox and IE -- I was timed out trying to access TBN, but had no problems accessing other sites.
Steve
/ Trouble loading TBN today! #4
Yep, had no luck accessing TBN this morning. Tried favorites, then tried searching Google, no luck. Countrybynet wouldn't open either. Let it rest until later and now it works.
Tucker
/ Trouble loading TBN today! #5
thought I,d been ball balled:D,now that I got on,gotta get off to take advantage of this beautiful day.Hope your day is looking as good as the one we,ve got!Dave
/ Trouble loading TBN today! #7
Seems like they were having server issues this morning. I had the same issue with both tractorbynet and countrybynet. I wouldnt worry too much about it as I'm sure Muhammad and others were sweatting enough for all of us once they realized there was an issue.:D
/ Trouble loading TBN today! #8
Yep, both TBN and CBN were missing in action for awhile this morning, but it wasn't long before it got fixed.
/ Trouble loading TBN today! #9
It has been happening again this afternoon...
maybe it happened cause I posted a picture...
as rarely as I do it, maybe the servers got worried!
:laughing:
J
/ Trouble loading TBN today! #10
:laughing:
J
Still happening now at 6:30 EST. I saw a lot of double-post's also in some forums...
/ Trouble loading TBN today! #11
/ Trouble loading TBN today! #13
the reply box took some time to open even
my guess is it doesnt blink any more often than most sites this size
still worriesome when you need your tractor fix :eek:
a cheaper way than to crank up the iron horse for no good or even half-good reason :cool:
/ Trouble loading TBN today! #14
it acting like a DNS problem...?
/ Trouble loading TBN today! #15
I'm still having timing out issues.
tom
yea--
I am still playing detective..
BUT-- from what I see the Internet routing is still going up and down on this one... It's what we call in the penalty box.. parts of the Internet are not allowing traffic to the end user... when a route annoucement is pushed and pulled back over a certain period of time and it matches the "penalty box" criteria the Internet peering points (IE AT&T and others) will pull the routes from annoucing it to their customers to prevent problems until the issues stabilize...
In this case, the maintenance window to replace the core routers went south and it could take another 2-4 hours for it all to be stable again since the flapping happened in the last 2 hours.. kind of like a water ripple....
BGP routing table entry for 208.100.32.0/19, version 74834003
Paths: (18 available, best #7, table Default-IP-Routing-Table)
Not advertised to any peer
7018 2914 32748, (suppressed due to dampening), (received & used)
12.123.1.236 from 12.123.1.236 (12.123.1.236)
Origin IGP, localpref 100, valid, external
Community: 7018:5000 7018:37232
Dampinfo: penalty 1446, flapped 15 times in 01:28:20, reuse in 00:03:14
From what I see, my ISP directly connects to the ISP at TBN in Chicago..
So I am getting slightly better response.. but the BGP routing session between my carrier and the TBN provider is going up and down...
J
/ Trouble loading TBN today! #16
this is all related to the ISP's maintenance from last night...
I suspect they have a few issues with the new Brocade routers they are using....
J
/ Trouble loading TBN today! #17
J
I'm guessing that a few techs are getting a headache.:laughing:
/ Trouble loading TBN today! #18
From what I see, I would guess it is a good bit bigger than just TBN...
a /19 IP block is 8190 addresses... -10% for routing overhead.. and they could be affecting a TON of websites...
:eek:
/ Trouble loading TBN today! #19
When I could not load the site from my bookmark...I could load it from the IP address...which usually indicates a name server issue, but not always...
/ Trouble loading TBN today! #20
Excuse my ignorance. Where can I find the IP address for a site?
Thanks,
Steve
2017 International WorkStar 7500 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A66736)
2017 International...
2008 FREIGHTLINER M2 CAB & CHASSIS (A67714)
2008 FREIGHTLINER...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2016 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
