hyrdaulic ram water pump
/ hyrdaulic ram water pump #1
wlf89
can anyone help me with my ram pump i had it running for about 2 yrs with no problems but lately it wont work. the water will run for about 2 days then it will quite but the pump is still pumping and is on 53 psi and before when it was working right it would run on about 49 to 50psi. so now when it quites working i can drain the pipe goin to the storage tank and it will run for another day or two and then quite i cant figure this one out is there something wrong with the pump you think? thanks alot
/ hyrdaulic ram water pump #2
:welcome:
Whew!! That was a loooong sentence. I'm outta breath. :D
From the description, I can't figure it out either. Hope someone here knows or has an idea for you.
i guess i will take it apart tomarrow and look at it do you think i would be better off to buy a simmons if i have to replace the check or foot valve i have aquasource now
/ hyrdaulic ram water pump #5
Other than saying your pump may be due for an overhaul due to the symptoms you mentioned I'm unfamiliar with Ram Pumps. :)
/ hyrdaulic ram water pump #6
Here is a good explanation of how a ram pump works. RAM PUMP
/ hyrdaulic ram water pump #7
Air chamber may be getting water logged.
took the pump apart and could not find anything wrong.
i can get the pump up to 54 psi and turn the cutoff off and it will hold pressure.
i have not had to mess with this pump but once in 3 years. (replaced oring)
all of a sudden it quit pumping water to the holding tank.
i have two tees in my supply line too check out and clean trash out if needed.
i thought i had somthing in the lines but i can not find anything wrong with them either.
the thing that gets me is around 300 feet below my holding tank, i can unscrew the cap on the tee and drain the line out, put the cap back on and it will pump to the tank again for about 10-12 hours and quits again.
when it is pumping, it is on 47 psi, when it quits, it is maxed out on 54 psi.
makes me think its getting air in the lines somehow.
/ hyrdaulic ram water pump #12
Check the maximum pressure the pump delivers against the required pressure to get to the tank.:)
Has the water flow the pump sits in changed in volume or velocity lately?:)
the spring has dried up alittle, but it is still keeping my lines and stand pipe full.
also what do u mean about Check the maximum pressure the pump delivers against the required pressure to get to the tank?
/ hyrdaulic ram water pump #14
Is the pump building up enough pressure to lift the water to where you want it.:)
well,
only takes 47 to get it there, when it stops running, the pump is still pumping and on 54 psi. acts like vapor lock.
2022 EZ-GO ELITE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
1057 (A63291)
1057 (A63291)
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
