toothdoc
Those last pictures are QI valve-not position control.
I just went to the shop and operated the lift.
When I pull the lift leaver HALF WAY UP, the lift starts raising very slowely and continuous--moving the leaver just a small bit further causes the lift to raise rapidly.
If I have the tractor idling and the lift arms lowered to maximum I can quickly move the leaver up to the stop, and the lift will raise completely in less then 3 seconds.
As you can see from the photos, moving my lift leaver to me or away from me makes no difference.
The difference I have noticed in this Kubota, from other tractors I have owned, is that after the emplement is raised to the desired position, the lift leaver returns to neutral position. On all other tractors I have had experience with, the leaver stays in that position and moving it down results in the empliment lowering. Mine will lower only when the leaver is pushed down past the neutral position.
Is it possible that this tractor is supposed to have QI and it is not working
What has me confused is that I have read that pulling the leaver toward you and moving it will result in 1/4" of lift.
Am I assuming wrong?
I still wonder what would be involved with converting a QI to position control. Maybe we should start a thread about that and see if anyone has done it?
Let us know if you need more help setting up the 3pt control.![]()
I've looked at this a little myself and from what I can tell, it's possible, but neither easy nor cheap. IIRC the 3pt control valve on the B2910 (maybe the b2320 Narrow also?) can swap into the lift cylinder housing on the B7800/B3200 and probably the smaller B series as well. The problem is that valve is nearly $600, then you also need all different linkage to control it, which would probably be another $100-200. Then you have to remove the lift cylinder housing, swap valves and reassemble. While that's not particularly difficult on this tractor, it's also not something that I would advice the home mechanic to try. I may look into this more someday (after my warranty is up), but I just don't know if it's worth the $700-$800+ that it would cost to get it all done.
I just don't understand why someone would dislike the QI system if they don't have to use it?
It is not the 1/4" function we hate, it is the lack of position control and the fact that it will not maintain an intermediate height or have a repeatable height setting.
My BX2200 didn't have the 1/4" feature and I hated it worse than my BX2660 or JD2305 with 1/4" valve.
As far as I can tell, the stops are just a point of index.
I only use mine hooking up equipment and would gladly pay $800 right now for position control.
Could you expand on this---Do you mean that the implement will not maintain the setting?
For instance---you are using a landscape box in soft dirt and you only want to move 2"---will the lift not allow this? Mine will:thumbsup:
My intent is not to argue or drive this post into the ground--I just want to learn:thumbsup:
So... wanna try that again?REALLY
I am 64 years old and I have owned, no less, then twenty tractors! I think I know how a tractor lift system works.
If you think I have QI ---Good for You---I have no problem with that:laughing:
Gee thanks buddy... what'd I ever do to you.EZ guys geez one of the things that makes this forum nice is that everyone is polite - Well except Diez.
You are correct, Sir! :thumbsup:What I like about the 1/4" valve is when I hook up an implement, by using the slow side of the control slot, it makes nice slow movements and doesn't jerk up and down. The negative is it will not stay up or at a set height ... the fact that the 1/4" valve will not maintain a height requires you to bump it back up once in a while ... It is my understanding that with a position control valve, it would hold the height you set. There are some other ways to work around it, but none as easy as just putting it at a position and it will stay there.
guys -
Everything is demonstrated on u -tube these days.
