I just went to the shop and operated the lift.
When I pull the lift leaver HALF WAY UP, the lift starts raising very slowely and continuous--moving the leaver just a small bit further causes the lift to raise rapidly.
If I have the tractor idling and the lift arms lowered to maximum I can quickly move the leaver up to the stop, and the lift will raise completely in less then 3 seconds.
As you can see from the photos, moving my lift leaver to me or away from me makes no difference.
The difference I have noticed in this Kubota, from other tractors I have owned, is that after the emplement is raised to the desired position, the lift leaver returns to neutral position. On all other tractors I have had experience with, the leaver stays in that position and moving it down results in the empliment lowering. Mine will lower only when the leaver is pushed down past the neutral position.
Is it possible that this tractor is supposed to have QI and it is not working
What has me confused is that I have read that pulling the leaver toward you and moving it will result in 1/4" of lift.
Am I assuming wrong?
