Best implement for road grading, for a 40HP CUT, regardless of cost?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #21
Picked the picture from the INTERNET.:)
Back when there were a lot of four wheel pull type graders. Also some tractors were extended and a blade mounted in the middle.
There were also side discharge elevating scrapers that moved the dirt from the ditch to the road.
If you go looking for land planes a current manufacturer should show up.:thumbsup:
Land plane?? :)
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #23
I got a Boxblade, Landscape rake, and a Rear blade with custom gauge wheels. I have to say that out of all of them, i like the rear blade the best. They all have their purposes but for just grading gravel, the rear blade is #1. If there are a lot of pot holes, the boxblade typically works better and if there are a lot of larger rocks mixed in, then the landscape rake works better. It all depends on your road. I dont only grade 1 driveway, but actually 2 so i needed all these to get the job done. :thumbsup:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #24
I like that one!
Bit of a cross wind there Eh.
Yeah! That's what came up when I typed "land plane" into Google Images.
This one too:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #29
This one too:
Man!, that thing must have had rabies and someone put it out its misery:laughing:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #30
whether you choose a box blade or a scraper (angle) blade...the most valuable asset you can buy is a hydraulic top link...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
