Best implement for road grading, for a 40HP CUT, regardless of cost?
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #21
Picked the picture from the INTERNET.:)
Back when there were a lot of four wheel pull type graders. Also some tractors were extended and a blade mounted in the middle.
There were also side discharge elevating scrapers that moved the dirt from the ditch to the road.
If you go looking for land planes a current manufacturer should show up.:thumbsup:
Land plane?? :)
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #23
I got a Boxblade, Landscape rake, and a Rear blade with custom gauge wheels. I have to say that out of all of them, i like the rear blade the best. They all have their purposes but for just grading gravel, the rear blade is #1. If there are a lot of pot holes, the boxblade typically works better and if there are a lot of larger rocks mixed in, then the landscape rake works better. It all depends on your road. I dont only grade 1 driveway, but actually 2 so i needed all these to get the job done. :thumbsup:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #24
I like that one!
Bit of a cross wind there Eh.
Yeah! That's what came up when I typed "land plane" into Google Images.
This one too:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #29
This one too:
Man!, that thing must have had rabies and someone put it out its misery:laughing:
   / Best implement for road grading, for a 40HP CUT, regardless of cost? #30
whether you choose a box blade or a scraper (angle) blade...the most valuable asset you can buy is a hydraulic top link...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
2014 Nissan Maxima (A50324)
2014 Nissan Maxima...
